Replace rubber brakes lines etc. just on age?
#21
The thread for new owners details what you should focus on. Many of these things are free or low cost if you diy.
Torque axle nuts. Valve adjustment. check torque of spaek plugs, the cam gear bolt. Change all fluids, including brake and clutch.adjust clutch rod. Clean maf. The list goes on...
As for mods for $125, I would do the UK mod. Also add a 3" cold air hose to stock airbox (from fender opening). These aural only mods will make the car sound like it should have from the factory. Will increase daily enjoyment of driving the car, yet still allow you to enjoy driving it daily...
#24
Probably good advice. I have either done, or plan to do, all those things you mention this spring. Most of them are done. I'm not interested in aural only mods. Call me crazy but I think the stock stuff sounds just fine.
My only reason for considering addressing these brake lines is because it could be a safety issue and they are 15 years old. If, as some seem to be saying, the age of the rubber lines is not a concern then I may rethink it. As I said, they look great and they perform perfectly fine now. I wouldn't change them out for stainless unless they should be replaced anyway because of their age in which event yes, I will probably put stainless on because they don't cost any more than OEM rubber. I guess I'm somewhat surprised that the years don't take a toll on these rubber parts even on a low mileage car.
#26
Yea, I have to say my gut feeling is that $100 to replace 15 year old brake lines just seems like the thing to do. I'm going back and forth. But, what is the down side anyway? Lose $100?
#27
$100 for piece of mind and an upgrade, there should be no thinking required.
I have Stoptech SS lines and the brakes on my MY03 feel a little better than the original lines, and much more firm compared to my MY06.
#28
If you do this, can you slice them open so we can examine the condition of the insides?
Wonder if there's any corrosion. Mine are 15 years old as well and I'm curious what brake fluid does to teflon lining over such a long period of time...
#30
I've always wondered -- why does stainless steel give a better "feel?" Since we know Honda lines have an interior with PTFE/teflon/etc -- and on these aftermarket lines, presumably the interior isn't stainless steel, so what gives?
I also can't find the country of origin on the SOS or Stoptech parts, but we know the Honda lines are made in Japan.
And since I'm always questioning, how are people so confident in the QA and R&D manufacturing/testing/longevity of the aftermarket brands on such a crucial [potentially life-threatening in case of failure] part?
