Squeaking/creaking front passenger side [VIDEO!]
Suspension NOISE front passenger side [VIDEO!]
Car is making a squeaking/creaking sound, front-right passenger wheel area while driving over rough roads, speed bumps, braking, etc.
To troubleshoot, I started to jack her up and found this SAME sound coming from the front, passenger side wheel well area whilst jacking... Pardon the rain and note that the car never made noise when jacking up before today (and the jack isn't making that loud noise). Noise starts at 0:18 as I jack her up [and 1:00 when lowering]!
Any ideas?
Any ideas?
Update:
Shock has roughly ~30k miles on it, and while I have hit a few potholes and bottomed out on a speed bump once or twice over the years, the suspension does not bounce up and down (or leak) like my previous old blown shocks...
Any ideas before I start throwing parts at it?
- Removed wheel, jacked up/down multiple times == NO NOISE
- Checked all the bolts to the shocks/A-arms == NO NOISE
- Re-installed wheel, jacked up/down == NOISE
- In the engine bay, leaning on/off the strut tower or quarter panel == NOISE
Help!!!!
Surprised there was no response to this. Car is literally undrivable, and sounds like someone pounding away on cheap mattress springs at a seedy motel in a bad part of town.
Here's a video of my driving in a parking garage:
Per my previous post:
- 0:20 seconds no throttle, steering left and right
- 1:10 braking and the noise is LOUD
- Suspension bolts right
- Subframe bolts tight
- Lug nuts tight
Do you have an ETD? The bracket on mine made a similar noise when it rubs against the fuse box bracket. It was really difficult to diagnose.
Other things to try: apply downward force on your engine and/or try to rock it. Maybe it's your engine mounts.
Sounds like bushings somewhere in the upper /lower control arm, could be the damper itself, could even be the steering rack/tie rod ends. Those are the areas to key in on. Id start with the easiest thing first, which is to loosen up the lower shock bolt and see if that bushing is binding/creating the noise. Systematically try and pinpoint where its coming from. We cant do that from behind the computer.
Thanks for replying guys!
Problem is, I can't get the noise to happen when the car is in the air and the wheel is off and I'm going nuts...
- No ETD, 100% stock
- I replaced both engine mounts ~50k miles ago with OEM. Last ones burst an orange, bloody color. I can push down on the engine without noise
- Pushing down on the passenger strut tower from the engine compartment causes the creaking
This sounds very familiar to my car that has poly swaybar bushings. When the bushings aren't lubricated it makes a ton of noise at any point of suspension travel. Is there anything aftermarket on the car?
P.S. Was hoping you'd reply -- I'm the guy in the yellow who came by to look at your taillights. Hope you're recovering well!
Grasping at straws -- gonna make an educated guess it's the ball joint from similar videos:
Not excited this bet is gonna cost me $67:
Honda Automotive Parts
I remember you! I just had surgery again to get my hardware removed but things seem to be going well... Good lucky with this.
