Steering collar install this weekend-quick question
Old 01-13-2017, 06:19 PM
bgoetz's Avatar
Default Steering collar install this weekend-quick question
I am doing the install over the weekend and have a question. I am going to do a front bump steer kit as well and was thinking it would be easier to do both at the same time and avoid unbolting the steering rack coupler. Can someone confirm that if I unbolt the actual rack itself there is no need to unbolt the coupler as specified in the DIY. I can't see why there would be I just figure it is easy enough to confirm.
Old 01-15-2017, 03:15 PM
noodels's Avatar
Read that the kit is not needed, 25mm drop i presume
Old 01-15-2017, 03:29 PM
bgoetz's Avatar
Depends, I think if you do an extended ball joint or especially an RCA it will further correct. But yeah for the most part I don't hear much noticeable change. That said I got them for $40 so why not?
Old 01-15-2017, 03:32 PM
bgoetz's Avatar
In any case if you do loosen those then obviously you don't do the steering coupler, but I would never choose four PITA bolts over one if you don't need to!
Old 01-15-2017, 03:39 PM
noodels's Avatar
Waste of $ ?
see if Andrewhake uses the with his setup,seems to be the Ohlins set up specialist
was going for them but was told not too ,there is 2 or more thicknesses as well.
up to you end of day
Old 01-15-2017, 04:13 PM
bgoetz's Avatar
Originally Posted by noodels
Waste of $ ?
If your asking a question that is off-topic, I don't have an issue providing an explanation as to why I decided to go with them. However, if your going off-topic to express an opinion that you already have, then try to keep the thread on topic.
I have talked with Andrew quite extensively about his setup, I actually went with 10k f/r based on that conversation and grabbed his 10k springs. At the end of the day while he has a lot of experience and knowledge it is all just opinion. You really have to visualize what changes are occurring to the geometry and decide if correcting it will result in a positive change. In this case it was $40, so it was worth tossing on for me
Acethriller
03-17-2016 10:21 AM
Jacques79
08-31-2007 09:29 PM
regmilla
09-29-2005 05:27 PM
krazik
01-07-2001 10:26 AM
Quick Reply: Steering collar install this weekend-quick question
