Tons of white smoke after long idle
I'm in Kansas City so it is cold but it definitely smelt like oil. I tried to get it to do it again and I can't now. Drove it around a little and then let it idle for 10 minutes and revved it and nothing. Wondering if maybe the pcv could've got a little gulp of oil for some reason? Really at a loss at what it could be besides possible my intake manifold having a loose bolt which I am going to check tomorrow. The one that would be causing 4 to leak I can't really get a good turn on without taking off a coolant hose
To get to that last bolt on the manifold I can do it with a combination of extensions and a swivel socket and some bright lights, but if you are smelling burnt oil then it won't likely be the manifold issue as that only affects coolant.
Mullallyman (01-14-2017)
I had that happen to me at the Dragon event a couple times and I've seen it on other S2000s that were in front of me, when changing directions, cornering, or just accelerating from a stop, it seems like the engine gets a gulp of oil from the pcv all of a sudden. I think it's white because it is a combination of oil, fuel, and water vapour, and I see it happen more often on vehicles with high flow cats or test pipes, not as much on oem cat equipped cars.
Pretty terrifying day! thought my S was going to be out for a while
Awesome thank you for the info! I have a high flow cat so that would make some sense. It seems like it would be easy for oil to get on top of that plate and then suck a little pool of it up. Time for a catch can! and its not the last one but the one before the last. Its the bolt directly underneath the #4 port. I can get a swivel on it pretty well and get it tight but the angle causes it to slip so i need to pull the coolant hose on the bottom of the air pump valve and then it gives plenty room. just a PITA
