Transmission Fluid Change DIY
Old 03-27-2008, 12:33 PM
moogleii's Avatar
Good thread!
Old 03-27-2008, 03:00 PM
Voodoo_S2K's Avatar
Good DIY, but you should never use a torque wrench to loosen bolts.
Old 03-27-2008, 03:25 PM
Mystiqueskillz's Avatar
Thanks for the nice write up. I was planning to take my car in soon for a transmission fluid change and rear differential change, but I think I will try and tackle it myself. Now you just need to have a DIY rear differential fluid change! lol.
Old 03-27-2008, 04:32 PM
mudring's Avatar
THANK YOU SIR!!!!
Old 03-27-2008, 05:04 PM
DR. FEINSTONE's Avatar
very nice detail organization.
Old 03-27-2008, 05:25 PM
NVMY4N's Avatar
Strong Work, Stickied.
Old 03-27-2008, 05:30 PM
S2KBLanton's Avatar
Great Job!
Old 05-12-2008, 03:59 PM
redlineracing's Avatar
Yep,did the same as you.New Honda fluid seems ok.I changed from the GM Syncro FM.
I used ramps instead of jacking/stands.EZ!
I like to chng the trans & diff fluid every 3rd oil change.
Great Writeup..
\db
Old 05-12-2008, 05:45 PM
Faber's Avatar
I picked up the same pump and used it for my last transmission change. It took forever to pump the fluid and the pump fell all apart.
I had to come up with another idea to make it less messy and efficient to get the fluid in.
I got two clear 1L bottles and a pump from a local beauty store. The pumps are much stronger and the tube is larger in diameter that it pumps fluid quickly. Get some 1/4 clear hose from home depot and fit it on the end. Voila!
The only thing is you have to pour the fluid first into the bottles, which is not a problem for me.
Old 05-12-2008, 08:32 PM
Supra-holic's Avatar
You can just run a 4-5 ft vacuum hose into the engine bay and funnel it in. Cost a couple of bucks.
Quick Reply: Transmission Fluid Change DIY
