Transmission Fluid Change DIY
Old 05-12-2008, 08:46 PM
  #21
Faber's Avatar
^ That works too, I prefer my method as it gives me control when to stop pumping fluid and I can put the filler bolt back on as soon as fluid starts to pour out.
Old 05-12-2008, 09:38 PM
  #22
ricepatrol78's Avatar
great write up!!! should make this sticky or something
Old 05-13-2008, 08:28 PM
  #23
MrRxZoCo's Avatar
nice DIY
Old 05-14-2008, 04:57 AM
  #24
NFRs2000NYC's Avatar
Just to add to this DIY....
When it comes to the tranny and diff, ALWAYS undo the fill bolt first. If you drain all the fluid, and you can't get the fill bolt off, you snap the head, whatever, you are SOL. ALWAYS take the fill bolt off first.
Old 05-14-2008, 05:26 AM
  #25
jphish's Avatar
Old 05-16-2008, 02:17 PM
  #26
s2k_man's Avatar
...Wow this is very easy pretty much as easy as an oil change. and to think i was going to let someone eles do this haha
Old 05-16-2008, 07:42 PM
  #27
Integra21's Avatar
when you say, fluid comes out the hole when its filled... meaning the tranny fluid will begin coming out the fill hole?
Also how precise are you in measuring the 1.6qt capacity? or should you try to get as much in there as it will hold (ie pump a little more and quickly plug with the bolt?)
thanks! will be my first tranny fluid change. movin up from just oil lol
Old 06-19-2008, 08:39 AM
  #28
FL S2K's Avatar
Thank you for saving me 40 bucks, gas, and time!
P.S: I did a bad thing... I used ramps instead of jack stands!
Old 06-24-2008, 04:15 AM
  #29
s2kbfast's Avatar
Awesome job.
Old 08-09-2008, 11:40 AM
  #30
xDeLiRiOuSx's Avatar
Thanks for the post! It is a great write up.
I figured my car is only 12 months old and probably won't need transmission changed yet. I guess I was wrong. I already have 30,000 miles on it.
So I did the flush and the shifter is smoother now.
Thanks!
-David
Quick Reply: Transmission Fluid Change DIY
