vin location on engine?
Old 07-20-2011, 05:28 PM
Stratocaster's Avatar
Originally Posted by f20kills
My 02 had a sticker in the front block with the VIN IIRC. Next to the crank pully...I could be wrong as that block is long gone lol
You know I think I remember that on mine as well. There was a bar code on it. In fact I think I still have that timing chain cover in storage. I completely forgot about that one.
Old 08-04-2011, 10:26 AM
traxtar614's Avatar
Originally Posted by ForkYou
I'm trying to locate the vin number on my engine and I'm having a hard time locating it ...
Can someone please tell me where it is .
Thanks
I had the same question a few weeks back. If you want to verify the block, look for the engine serial on the block right above the intake header (if you'e looking at the engine bay head on, its on you right, drivers side, probably easiest to stand over your driver side front wheel well and look) you SHOULD see a engraved serial number. unfortunatly this number has no correlation with the VIN, but if you have the originaly windown sticker of the car, it should match up with the engine serial number listed on the upper right hand corner of the window sticker. Hope that helps.
S2K VINCE (12-23-2023)
Old 08-04-2011, 12:07 PM
Billman250's Avatar
Received 1,244 Likes on 759 Posts
Front white sticker on timing cover, and stamp on left front of block show the same number...engine number. Will not show VIN.
Old 11-08-2014, 04:54 PM
abroke1's Avatar
Originally Posted by Stratocaster
it is NOT on the Block. The block has a serial number that does not match the VIN. The head has a VIN on the very back side, next to the firewall. You will be hard pressed to see it without pulling the head out of the car.
DANG...well buying from original owner guess it is okay
Thanks
Old 11-08-2014, 04:56 PM
abroke1's Avatar
Thanks
Old 11-08-2014, 04:58 PM
abroke1's Avatar
Originally Posted by abroke1
Originally Posted by traxtar614' timestamp='1312482413' post='20847564
[quote name='ForkYou' timestamp='1311098823' post='20794137']
Thanks
[/quote]
Well it is original owner...hopefully he still has the window sticker but I guess that won't be a deal breaker.
Thank you
plizzat
05-01-2017 03:25 PM
miravete
06-17-2014 03:25 PM
traxtar614
07-16-2011 11:02 PM
tntrac
06-13-2010 10:05 AM
apex2k
01-09-2005 07:32 PM
Quick Reply: vin location on engine?
