Issue with gas furnace - Any experience with this?
We had a new gas furnace installed about 6 years ago. Time flies. We've never bothered having it cleaned, as we were under the impression that was more necessary for oil burners/furnaces. Rick changes the filter regularly.
Twice in the last little while the furnace does not cycle on to heat, and the temp drops more than two degrees past the set temp, last night it was 4 degrees and still the heat did not turn on. Rick has turned the main switch off and on again and it works fine. We have also noticed the thermostat (digital) buttons are not as responsive as they work, especially if adjusting down, have to hold/push the button a few times.
I called for service but they have warned me that if the system is not malfunctioning when they arrive they may not find anything, I get that. I asked if there was something that possibly just needs cleaning, and there is some kind of rod. So I have asked them to come by and clean the furnace $99.00 (cash or CC only). Thinking of having them replace the thermostat as well $85.00.
Could the thermostat be more likely to be the culprit here?
Lots of electronics is some new furnaces but I suspect the thermostat. Consider a "smart" thermostat. I put a Honeywell version (Home Depot) on my 7 year old system a couple of years ago. Mainly for remote access because we're often away from this house. It works wonderfully. Has a fan setting for Circulate that runs it periodically during the day to keep the temps even. These need some sort of special wire (C?) in the system to work. New furnace in our main house this past summer has a similar but more basic thermostat (also remote control).
-- Chuck
-- Chuck
OK, guy just left. He thinks the issue could have been that there was a little cleaning needed, but I had him change the thermostat as well. He said if it happens again to check for a code that will be visible.
We are not real DIY people lately....no time. I know I probably just paid $85.00 for a $20.00 thermostat........
I would lean towards a good cleaning. In the newer furnaces there are multiple sensors to detect pressure differences, current flow to ignition coils, presences of spark at igniter, etc. By cycling the power you would have reset any errors the system had detected.
I'm hoping you are correct. He said all the parts looked fine. I didn't hear any kind of vacuum going...not sure how he cleaned it...hmmmm. Probably used a swiffer.
LOL. Never thought of that Dave
We have ours cleaned every two or three years. The igniter needs to be replaced every three years. The original igniter lasted 10 years. The replacements are aftermarket and suck.
