Missing a lug nut, is it still safe to drive? - S2KI Honda S2000 Forums
LinkBack Thread Tools
Old 09-01-2009, 08:55 AM   #1
Default Missing a lug nut, is it still safe to drive?
I found that one of the lug nuts on one of the front wheels is cross threaded, and so I had to leave it out. Now there is only 3 of 4 lug nuts installed on that wheel (FWD car). I wonder if it is safe to drive the car on the freeway up to 55 MPH. I'd feel much better if the wheel had five lugs and missing one, but since this wheel only has four lugs, I don't feel as confident if it is missing one lug nut. I will get the lug stud replaced soon, but meanwhile, should I use the car? What do you guys think?
WhiteS2k is offline   Reply With Quote
Old 09-01-2009, 09:56 AM   #2
Legal Bill's Avatar
Get a die or thread chaser and clean the stud up. Buy a new lug nut. Install new nut on cleaned up stud. All that should take about an hour including the trip to sears to buy the tools if you don't have them.
Legal Bill is offline   Reply With Quote
Old 09-01-2009, 10:24 AM   #3
Gold Member
Vanishing Point's Avatar
Make sure you buy the right size metric thread chaser for the stud.
Vanishing Point is offline   Reply With Quote
Old 09-01-2009, 10:29 AM   #4
Legal Bill's Avatar
^Yes. If you have another car, jack up the one with the bad stud and take off the wheel on the bad corner. Bring one of the lug nuts with you and tell the sales guy you need a thread chaser to clean up the matching stud. Do not let him sell you a tap. Clean up the thread with the die or chaser with the wheel off. Then remove the chaser and reinstall the wheel with a new lug nut on the cleaned up stud. Do not try to use the lug that corss threaded the stud. Toss that out and get a new one.
Old 09-01-2009, 11:22 AM   #5
Thanks for all the inputs. I've not heard of a "chaser" before. Actually I also thought the lug nut was bad also, so I swapped it with another one and hand threaded the "bad" lug nut onto another stud and everything went smooth. No binding or anything. I then tried the swapped out lug nut on the "bad" stud (by hand) and again, it would not go very far before it stopped. I my conclusion is that the lug nut(s) are all good and it was the stud that was bad. So will a "thread chaser" clean up the bad stud or would I need to install a new stud?
Meanwhile, do you think it is safe to drive the car (up to 55 MPH) with one missing lug nut? Thanks.
Old 09-01-2009, 12:00 PM   #6
valentine's Avatar
^^ I would not drive with any lug nuts missing. It seems to be a fairly simple repair, so I'd get the repair done before getting on the highway. The balance may be off causing further damage to other lug nuts. Just sayin'.
valentine is offline   Reply With Quote
Old 09-01-2009, 12:46 PM   #7
Lainey's Avatar
I often operate with a loose screw, but I prefer to drive a car with all lug nuts specified.
Lainey is offline   Reply With Quote
Old 09-01-2009, 01:14 PM   #8
Member
RC - Ryder's Avatar
Since the harder stud usually survives, I'd install one of the lug nuts from the rear wheel, and then drive reasonably until I could get another one.
RC - Ryder is offline   Reply With Quote
Old 09-01-2009, 01:20 PM   #9
Legal Bill's Avatar
On a 4 stud wheel, I would be nervous about driving with three. that said, if I needed to use the car to get to sears to buy the tools, i would probably risk it and drive very carefully.
Old 09-01-2009, 03:24 PM   #10
Member
boltonblue's Avatar
it all depends, what's your life worth?
it would seem the downside potential is much higher than the short term benefit of risking it.
boltonblue is online now   Reply With Quote
Thread Thread Starter Forum Replies Last Post
***MEGAMEET 6 INFORMATION 60+ S2000*** Back-cracker California - Southern California S2000 Owners 132 06-12-2006 09:07 AM
would you be scared driving an Elise on highway? rai Car Talk 22 11-18-2005 09:14 PM
Steppin' out Philos UK & Ireland S2000 Community 16 10-21-2005 08:38 AM
Pete Carroll: "We're not playing very well right The Raptor California - Southern California S2000 Owners 1 10-19-2005 09:55 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
