Can't find A30 pin for Kpro
Can't figure out what connector on my Kpro is the original A connector so I can connect my aem wideband to the ELD spot. Previous owner had no idea how to correctly wire and made a mess. Guessing there was a different standalone in the car befor the Kpro was installed. Currently upgraded to Kpro4 and want to hookup my wideband to the Ecu. Can't someone point out the correct connector.
If you have kpro4 you don't connect it to any of the ecu connectors.
Use the analog or digital inputs inside the ecu on the kpro board instead.
https://www.hondata.com/help/kmanage...put_wiring.htm
https://www.hondata.com/help/kmanager/analog_wiring.htm
What inputs are suggested for the AEM uego? Reasoning behind this all is im boosted, and I think my stock 02 sensors are shot. In Kpro they only read 10.7. I recently installed the aem uego 3 months ago with the new kpro4. So to avoid buying new o2 sensors I read I can make the car run in open loop with the new wideband. Recently with the weather changing in New York my afr under WOT hit 12.6-12.8 today and I'm trying to see if tables need to be adjusted and would make fine tuning easier.
Kpro seems to have support for at least a couple of AEM widebands with digital signal, 30-4100 and 30-2310.
I guess analog input is the most used though and it works just as good as long as you wire and ground it correctly.
I'm running kpro4 as well and I've removed both my stock sensors and using a PLX wideband instead, works great in closed loop.
Hondata Kpro help page is your friend. The ECU pinout is for normal kpro, but use the same way to count the pins as you would for the S2000. top left is 1, bottom right is highest number of pin on that connector/
https://www.hondata.com/help/kmanage...l?contents.htm
For Kpro 1 and 2 use the A30 ELD input.
For Kpro 3 and 4 use input analog 1 (which is actually input analog 0 on the pigtail.
See the attachment. You have 8 analog inputs for Kpro 3 and 4, but they are listed as analog inputs zero through seven (0-7). By default, I would use the first analog input (zero), for your wideband input.
I didnt notice intially, but I think the OP should consider reworking the wire harness. I would solder every connection for the ECU. I have never seen so many modifications on so many wires for the stock ecu.
Anyway if I upload my kpro tune onto the forum can someone take a look at it tell me how bad I got ripped off because I'm very unhappy.
