Oil leak... from the oil pan or somewhere else?
Old 12-07-2016, 10:29 AM
cj_in_seattle's Avatar
Default Oil leak... from the oil pan or somewhere else?
Helo all. Could you take a look at these pics and tell me if you think it's just my oil pan or something else? I think I see some oil around my vtec solenoid. Not sure. I tried to take pics from different angles but it was really dark out so they're not great. Let me know.
Old 12-07-2016, 10:36 AM
Slowcrash_101's Avatar
Looks like it's your oil filter.
Old 12-07-2016, 03:42 PM
I'm going to try pressure washing off this section of the engine and determine where it's coming from. I'm hoping it's something simple.
Old 12-07-2016, 04:05 PM
jst2878's Avatar
Oil is dripping from the oil filter. Its loose or the vtec solenoid is leaking just above the filter
Old 12-07-2016, 04:25 PM
Hfreak's Avatar
Agreed, change your filter and install an OEM filter.
Old 12-07-2016, 04:36 PM
jst2878's Avatar
Is there a crush washer on the drainbolt? Dont bring your car for oil changes to the same place
Old 12-08-2016, 05:35 AM
It looks like my oil filter tried to walk off. Is there a way to keep it in place?
I came across an oil filter "holder" that supposed to keep it from moving. Does anyone use these and your thoughts on them?
http://www.gotuning.com/product_info...oducts_id=1093
Old 12-08-2016, 07:48 AM
flanders's Avatar
If you use the OEM filter and torque it correctly (hand tight is not enough) you shouldn't need one of those holders but I guess it doesn't hurt either.
Old 12-08-2016, 08:07 AM
For my previous cars, I was told that hand tight was enough or I could damage the gasket. Is it different for this car? How much to torque it down?
Old 12-08-2016, 08:16 AM
flanders's Avatar
Yes this car is different since there is metal to metal contact when filter is torqued down.
The specifications are printed on the OEM filter, I think it's 7/8 turn or 22Nm.
You should be glad that you found this early, it could have cost you the engine.
Quick Reply: Oil leak... from the oil pan or somewhere else?
