Antifreeze Coolant
Antifreeze Coolant
Hello members of the forum, I just have some quick "noob" questions to ask you all. Would greatly appreciate it, if I could get it clarified. When I bought my S2, my coolant reservoir contained blue antifreeze coolant. After countless drives, the fluid is finally depleting to where I would need to refill it again soon. My concern is, can I just use Walmart's Prestone antifreeze coolant? I know that the Prestone's coolant could be different, as to the color of the fluid compared to the one I have in my reservoir now, which is a blue fluid. That being said, will it also be bad for my radiator if I mixed the Prestone antifreeze coolant with the current fluid that is still currently in my system (blue antifreeze fluid)?
Thanks!
Thanks!
Thanks!
Thanks!
The overflow bottle working? Coolant loss is not normal. Antifreeze is less efficient than ordinary water and adding distilled water won't hurt rather than risk a damaging antifreeze. Depends on your climate how dilute you can go.
-- Chuck
-- Chuck
Some coolant loss over a VERY long time is ok. Having your entire reservoir gone in a short amount of time is not normal unless the previous owner used mostly water.
It's a $10-12 difference between the Honda and Prestone. Nothing wrong with Prestone itself, but I wouldn't mix the two.
