Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
****InlinePro Engine build specials!! ****
Old 02-01-2017, 05:17 AM
Former Sponsor
InlinePRO's Avatar
Default ****InlinePro Engine build specials!! ****
Hey everyone,
We are long overdue on the forums and since we are coming back InlinePRO would like to offer a 5% discount on any short or long block build!!!
You can send me a PM or email. Chase@InlinePro.com, Info@inlinepro.com or call the shop and ask for Christian!! Phone: 703-455-5805 make sure you let him know you saw this on S2ki since this pricing is exclusive to S2ki
Fuel Injector cleaning service $100
Engine Sleeving closed deck
F Series $1495
J Series $2550
*InlinePRO closed deck sleeves are used
*Prices are with customer supplied cores
InlinePro Signature Short Blocks
F Series $3995 $3795.25!!!!!
J Series $5995 $5695.25!!!
*includes: inlinePRO sleeves, CP pistons, inlinePRO rods, ACL race bearings, Hot tank, Resurface, Bore, Hone, Gap rings,
Measure Bearing clearance, Balance, Micropolish Crankshaft, Blueprint, Assembly
InlinePro Signature Cylinder Heads
Stage 0 - F20C/ F22C $1195.00
Stage 1 - F20C/ F22C $1595.00
Stage 2 - F20C/ F22C $1895.00
Stage 2.5 - F20C/ F22C $1995.0
Stage 3 - F20C/ F22C $2495.00
Stage 3.5 - F20C/ F22C $2695.0
Stage 4 - F20C/ F22C $2995.00
**Pricing with customer provided core**
Machine Shop Services
Hot Tank Block $75
Hone Block* $187.50
Bore .020 Over $187.50
Bore Custom Size* $300
O-Ring Block $250
Bore and Hone FRM Sleeves $375
Finish Hone FRM Sleeves $200
*Customer must supply necessary components for proper measurements
Engine Building Services
Short Block Assembly
*Hot tank, Resurface, Bore, Hone, Gap rings,
Micropolish Crankshaft, Blueprint, Assembly $1250
Long Block Assembly: Turbo
*degree in long block assembly $650
Long Block Assembly: Naturally Aspirated (larger than factory cams)
*degree in long block assembly $950
* OEM sleeve F24C performance build includes inlinePRO piston set, InlinePRO F24C connecting rods, New modified OEM K24 crankshaft, ACL race bearings, disassemble, hot tank, resurface block, bore and hone FRM sleeves, micropolish crankshaft, gap rings, measure bearing clearance, balance, blueprint, and assembly. $3995 (you must provide core shortblock)
* OEM F20C/F22C sleeve performance build includes inlinePRO piston set, InlinePRO connecting rods, ACL race bearings, disassemble, hot tank, resurface block, bore and hone FRM sleeves, micropolish crankshaft, gap rings, measure bearing clearance, balance, blueprint, and assembly. $2995 (you must provide core shortblock)
Attached Thumbnails ****InlinePro Engine build specials!! ****-ip-engine-build-.jpg
InlinePRO is offline
Sherxiong (12-25-2020)
Old 02-01-2017, 09:23 AM
Former Sponsor
Tougefactory's Avatar
**heavy Breathing**
Tougefactory is offline
Old 02-13-2017, 04:43 AM
Former Sponsor
InlinePRO's Avatar
bump
Old 02-14-2017, 05:15 AM
Former Sponsor
InlinePRO's Avatar
Replied!
Old 02-20-2017, 05:53 AM
Former Sponsor
InlinePRO's Avatar
All Pm's replied!
Old 03-14-2017, 11:47 AM
Former Sponsor
InlinePRO's Avatar
How much boost you ask? ALL OF IT!
Bump!
Old 01-16-2018, 12:36 PM
Car Analogy's Avatar
Received 1,315 Likes on 993 Posts
Default Stock Rebuilds
Am I reading this correctly. Regarding a stock rebuild, under Machine Shop services, you list:
Does that mean if the block can be saved (there are no scratches too deep, or cylinder out of round, etc), that you will overbore the factory FRM cylinders to fit factory 0.25 mm oversize pistons, for the price quoted above?
Thx!
Car Analogy is offline
JSanford2032
Member S2000 Classifieds and For Sale
04-28-2019 11:54 AM
second2none
08-16-2009 11:08 AM
second2none
66
08-04-2009 05:57 AM
SIIK2NR
San Diego S2000 Owners
295
03-19-2006 12:56 PM
Quick Reply: ****InlinePro Engine build specials!! ****
