Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
Ballade Sports 00-09 Low Friction S2000 Camshaft Kit
Old 02-15-2017, 07:37 PM
Former Sponsor
BalladeSports's Avatar
Default Ballade Sports 00-09 Low Friction S2000 Camshaft Kit
Ballade Sports Low Friction S2000 Camshaft Kit includes an Intake Camshaft, Exhaust Camshaft and an Adjustable Drive Gear to dial in every ounce of performance. It is well known the F20c & F22c engines have excellent internal combustion components. We at Ballade Sports have taken this to an even more finite level of precision. Our low friction cam shafts offer increased revolution speeds by balancing and detailing the original factory camshafts. The cam journals are polished and given more clearance to allow the assembly to spin faster with lower friction. In addition to our kit we offer our Ballade Sport Adjustable Drive Gear. This allows the user to advance or retard the cam timing simultaneously up to 3 degrees. Engines with old timing chains can benefit with the use of this adjustable drive gear to re-calibrate all the timing indicators to their F20c & F22c engines ie: Intake, Exhaust, & Crank Pulley. It is especially crucial to re-calibrate cam and crank timing for resurfaced cylinder heads or decked engine blocks, which leave you with longer timing chains. The drive gear comes fully assembled with the idler gear and sprocket. It is made out of hardened steel matching the same HRC rating as the original Honda equipment. Once this kit is installed properly the performance gains can increase up to 6-10 whp.
List Price: $699.99
Ballade Sports
BalladeSports is offline
Old 02-17-2017, 12:27 PM
S2000Craig's Avatar
Are you guys going to offer just the Adj. drive gear for sell for guy with toda and skunk2 cam gears
S2000Craig is offline
Old 02-17-2017, 01:34 PM
Former Sponsor
Yes this is already available on our website separately. Pm'd
BalladeSports
04-06-2017 04:03 PM
vananron
02-27-2003 08:14 PM
Quick Reply: Ballade Sports 00-09 Low Friction S2000 Camshaft Kit
