EVS Tuning High Capacity Differential Cover
Former Sponsor
The EVS Tuning High Capacity Differential Cover is a must have for track enthusiasts. S2000 Differential design is probably one of the weaker links in the drive-train.. with OEM only taking up less than 1 quart, causing overheating of the fluids and decreasing performance and lifespan of the diff and gears.
This cover will increase the fluid capacity to approximately three times that of the Oem cover. Included are removable plugs to allow installation of an oil cooler, in order to decrease temperature. This cover will help increase the lifespan of the differential and lessen the amount of fluid changes needed between track events. Cover also is internally baffled to make sure proper fluid movement within the unit.
Designed in the USA, it's manufactured in Japan at a very sophisticated factory to assure quality and precise fitment on the S2000. Installation is bolt on with no modifications or welding required.
We are doing a groupbuy for the batch we are getting (End of January). Retail 895 but for initial 10 orders we will be offering at a price of 799 + free shipping. Accepting pre-orders at the moment so it'll be on a first come first serve basis and free shipping will only be good for 10 Units. Differential cover will include magnetic drain plugs since it uses a different size. We do have a install special for $250 if you are local (includes removing differential from car) + fluids. Feel free to contact me via email / private message / phone if you have any questions.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Dennis 626.336.3400
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Dennis 626.336.3400
Is this using the same manufacturer as the high capacity diff cover from Trust?
http://www.trust-power.com/php/updat...402165etc00116
