Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
INVIDIA,GREDDY,APEXI,BUDDY CLUB EXHAUST SYSTEMS!
Old 01-18-2010, 05:54 PM
Former Sponsor
lsd motorsports's Avatar
Default INVIDIA,GREDDY,APEXI,BUDDY CLUB EXHAUST SYSTEMS!
LSD IS OFFERING INSANE DEALS ON THESE FOLLOWING BRANDS.!
--PM ME FOR SPECIAL S2KI PRICING---
Buddy Club Pro Spec Dual Muffler Catback Exhaust Honda S2000 00-03
Buddy Club Pro Spec is a super light weight and highly efficient muffler that is made to perform for circuit runs. In its street version, to optimize torque in the low to mid speed range, it is equipped with an efficient middle silencer (resonator). Pro Spec Mufflers were designed for high performance as well as meeting sound level standards. With its deep throaty tone, it echoes its racing lineage.
The middles silencer achieves both exhaust efficiency and sound dampening requirements. Usual mufflers are designed to "muffle" sound and results in restricting performance. Buddy Club mufflers, with results of trial and error, have developed the highest possible performance while maintaining a low throaty tone. Only the finest material are used, that meets high endurance, light weight, and excellent fit.
The inner silencer is included with all mufflers. When installed it meets volume safety standards. Improvement in durability can be seen by the use of "band- stay" hooks as attachment to the main silencer.The absence of welds help maintain the light weight frame. In continuing the light weight form the muffler tip is made with a slight incline cut. This is a demonstration of commitment to performance and style. A mark of quality and craftsmanship, all muffler are engraved with the Buddy Club insignia.
Greddy Racing RS Turbo Catback Exhaust Honda S2000 00+
GReddy Racing Ti-C Cat-back Exhausts combine the design, looks and flow of our Full Racing Titanium systems with the durability, deep sound, value and large application list of our other Stainless Steel street systems. This fusion of aggressive styling and practical construction, makes this the logical choice for both Race and Street Enthusiasts. The systems are comprised of a Titanium heat-treated tip, polished stainless steel muffler, unpolished stainless steel piping. It improves high and mid-range performance while still allowing for suitable sound levels when used with the included tuned Tri-mounted Silencer*. *Most applications below 92db, with all under 94db. The large list of applications include 80mm piping for Turbo applications and 50-60-70mm for Normally Aspirated vehicles. (usually 60mm)
Racing Ti-C Specs
TIP:
-Material: Titanium
-Sizes: dia.102mm or dia115mm
-GReddy Embossed, with heat treated tip
-Removable Silencer w/ vibration-free tri-mounting
MUFFLER:
-Material: 443 Stainless Steel
-Canister Sizes: dia140mm or-dia160mm (w/ various length)
-Inlet sizes: dia. 50, 60, 70 or 80mm
-Compact Power Extreme II design
-Advanced Robotic TIG welding
-High Flow Straight-through design
-Specifically tuned internal construction w/: various perforated tubes designs
-Protective stainless steel mesh
-Propriety composite cube sound suppression
RESONATOR:
-Material: SUS304
PIPING:
-Material: 409 Stainless Steel
-Sizes: dia 50-80mm
-Minimal mandrel-bends for maximum flow
FLANGES:
-Material: 304 Stainless Steel
-Strong, Light-weight pressed flanges
Dual Muffler Exhaust
AP2 models require AP1 rubber hangers.
Buddy Club Spec III Catback Exhaust Honda S2000 01+
Buddy Club SPEC III exhaust systems are the lightest stainless-steel exhaust system on the market today. Its simple straight thru design creates an increase of exhaust gas velocity in order to enhance its efficiency. The resonator on the main pipe is specially designed to enhance torque in the low to mid RPM range.
All of Buddy Club's mufflers are made with SUS304 stainless steel, 1mm thick wall material is used for main pipe. and the 0.8mm wall stainless is used for main silencer. This combination of materials creates a super light weight system. Moreover with the included bolt in silencer installed, the SPEC III exhaust system meets most legal sound levels for day to day street use.
Improvement in durability can be seen by the use of "band-stay" hooks as hangers for the main silencer. The absence of welds in this area help maintain durability of the system.
The bolt-in inner silencer is included with all systems. When installed it meets most legal sound levels for day to day street use.
Buddy Club systems are manufacturered for a perfect length to expel the exhaust gasses completely out and away from the car. This translates to less excess exhaust dirt and grime on the back of your car, and also elimination interior cabin exhaust "drone". The muffler tip is angle cut. Buddy Club's commitment to performance and style is consistent throughout from tip to tip.
A mark of quality and craftsmanship, all mufflers are clearly engraved with the Buddy Club insignia.
Spec III Exhausts are designed for JDM spec vehicles, may need modifications to fit USDM version vehicles.
HONDA S2000 Q300 SINGLE LAYER TITA. TIPS CAT-BACK
If you are looking for performance and aggressive look that resembles OEM look, Invidia offers the motorsports enthusiasts a brand new line-up of Invidia Q300 Exhaust constructed with high-quality SUS304 stainless steel, CNC-machined flanges, Double Wall Rolled Edge tips and manufactured with a polished finish. Each system features mandrel-bent stainless steel piping for maximum exhaust flow and reduced back pressure.
Piping Dia.:70mm
Tip Dia.:101mm
HONDA S2000 Q300 STAINLESS STEEL TIPS CAT-BACK
Piping Dia.:70mm
Tips Dia.:101mm(Dual Wall)
If there is a exhaust system that you do not see listed here feel free to post on this thread or PM me . We also carry a wide range of headers and test pipes for the S2000
__________________________________________________ __________________
LSD Motorsports
5241 Lincoln Avenue
Unit A-4
Cypress, CA 90630
Telephone:
(877) 573-6686
(714) 220-1245
Fax:
(714) 808-1312
Email Address:
Alex@lsdmotorsports.com
ALEXATLSD
lsd motorsports is offline
Old 01-18-2010, 06:10 PM
R Legend's Avatar
pm me price on greddy dual to 75248
R Legend is offline
Old 01-20-2010, 09:45 AM
Former Sponsor
TORNADO BUMP!
Old 01-21-2010, 04:40 PM
Former Sponsor
GROUP BUY PRICING AVAILABLE
Old 01-22-2010, 11:25 AM
Former Sponsor
tax returns are just around the corner!
Old 01-25-2010, 12:11 PM
Former Sponsor
pms send
Old 01-30-2010, 09:15 PM
status2k's Avatar
Price for bc spec iii shipped to 11735. Thanks
status2k is offline
Old 01-31-2010, 08:41 PM
S2Kevint's Avatar
Just e-filed my taxes!
Plz PM me pricing on the blue tipped q300 for ap2. thanks.
shipped to 94565
S2Kevint is offline
Old 02-01-2010, 07:45 AM
'ringmeister's Avatar
Please PM me price for Greddy Ti-C Single shipped to 08534, thanks
'ringmeister is offline
Old 02-01-2010, 04:08 PM
Former Sponsor
NEW WEEK BUMP
Quick Reply: INVIDIA,GREDDY,APEXI,BUDDY CLUB EXHAUST SYSTEMS!
