URGE Scavenger System Launch;
Sponsor
URGE Scavenger System Updates! Now V2 Exhaust
43 Scavenger Mid Pipes Sold!!
OEM Motor; Gern Pipe vs Test Pipe vs Stock
260+ WHP 2.3L Built Motor; Gern Pipe Full Tune vs Gern Pipe Quick Tune vs Berk 70mm HFC Full Tune
Gern Pipe $1200
Gern Pipe $1200
- Patented Mid Pipe Designs produces more HP than a Test Pipe
- Gernby Tuned Expansion Chamber that creates Scavenging Pulse from 3500 to 6500 RPM
- Expansion Chamber reduces Drone from 3500 to 6500 RPM
- Expansion Chamber also includes sound baffling on non STR versions
- 2.5” Honda Header Flange, Connects w/ OEM and common aftermarket headers
- 304 Stainless Steel Tubing
- Integrated Hi Flow Catalytic Converter
- 3" Flange Outlet
- URGE Spec; connect to URGE 3 Exhausts
- STR Spec; Expansion chamber opens with in 6” of OEM Cat, Quote from the September 2014 fastrack in response to letter #14037: "In regards to the location of non-OE catalytic converters the STAC considers the inlet to be the location where the expansion chamber begins. Additionally, there are currently no restrictions as to where the catalyst medium may be located within the assembly"
- NEW URGE Dual Exhaust V3; $1100
- Make your own Exhaust System
- Weld into your current system
- 3" Inlet Flange
- Ultra Light Weight Coast Fab Mufflers
- Modular Design that can be repacked as needed
- Dual Mufflers are 2.5" ID x 12" Short to reduce weight
- Dolphin Tips for further sound reduction
- Reduced Weight from Previous Exhaust by >40%
- Ultralight & Rebuildable Mufflers
- Mufflers weighs 1.8 lbs each!!
- $300 MSRP per muffler
Sponsor
Reserved for Commitments and Order Times
1. AD, URGE Spec Gern Pipe & T1R Dual
2. ST, STR Spec Gern Pipe & T1R Dual
3. BeeB, URGE Spec Gern Pipe & T1R Dual
4. Conedodger, STR Spec Gern Pipe & T1R Dual
5. Korinfox, STR Spec Gern Pipe & T1R Single
6. z2theander, URGE Spec Gern Pipe & T1R Dual
7. Topplayer, URGE Spec Gern Pipe & T1R Single
8. MK, STR Spec Gern Pipe & T1R Single
9. neurotic, STR Spec Gern Pipe & T1R Single
10. sillyboybmxer, STR Spec Gern Pipe & T1R Single
11. RS, STR & Gernby Spec Gern Pipe
12. OB, URGE Spec Gern Pipe & T1R Dual
13. thepoi, Gernby Spec Gern Pipe
14. jaboo008, URGE Spec Gern Pipe & T1R Dual
15. SHG_James, URGE Spec Gern Pipe & T1R Single
16. S4Speed, URGE Spec Gern Pipe & T1R Dual
17. JE, URGE Spec Gern Pipe & T1R Dual
18. JeremyClarkson, URGE Spec Gern Pipe & T1R Dual
First Batch Order Cut off
Next 10 or August 15th is the next batch
19. SA, URGE Spec Gernpipe & T1R Dual
20. ericg, URGE Spec Gernpipe & T1R Single
21. PE, URGE Spec Gernpipe & T1R Dual
22. s2sik, URGE Spec Gernpipe & T1R Single
23. Fongu, URGE Spec Gernpipe & T1R Single
24. MS, URGE Spec Gernpipe & T1R Single
25. MK, URGE Spec Gernpipe & T1R Dual
26. DA, URGE Spec Gernpipe & T1R Dual
27. DW, URGE Spec Gernpipe & T1R Single
28. AK, URGE Spec Gernpipe & T1R Dual
29. BG, URGE Spec Gernpipe & T1R Single
Sponsor
Gernby has an Invidia that he used to test fit. It is very close to the T1R exhaust inlet, you should be able to go with URGE Spec Midpipe only and adjust your exhaust hangers or rubber mounts to fit.
Sponsor
We have been too..
Thank you. Its all about S2000 Passion, all of our profit has been reinvested in R&D and the next product
Ill ping Gernby for db readings. Any specifics on what you are looking for.
One HFC did get loose out of one of Gernby's original 50. We can provide a new cat for $100 and it would cost a few $100 to re weld back in. For less than $300 it can be replaced. Any Forced Induction Car running rich will burn up any cat, OEM, Heavy Metal, etc.
