Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
Öhlins DFV Billet Lower Mount - Fix Your Ride Height Issues!
Old 12-06-2016, 09:32 AM
Sponsor
SakeBomb Garage's Avatar
Originally Posted by andrewhake
"-Up to 50mm lower ride height as compared to standard DFV mount
-Adjusts to 40mm higher ride height than standard DFV mount at shortest height"
eh? how could this possibly adjust to 40mm higher ride height than the standard DFV mount? What is the actual range difference vs. the standard DFV mount? What is the minimum amount of threads engaged that Ohlins recommends with the DFV? I think they listed this in the user manual maybe? Does this lower mount allow the damper to thread all the way through the mount?
Note the emphasis on "standard DFV mount at shortest height". The shortest the unloaded standard rear DFV can be is ~410mm (top hat to bottom bolt). This mount reduces that number to 378mm (32mm shorter) and has a 56mm adjustment range making the max possible length 434mm.
As this effect happens through the motion ratio, these numbers in terms of ride height become ~50 shorter & ~90mm adjustment range. Again these numbers are relative to the stock mount at its MINIMUM HEIGHT. As that is where the majority of people are set that is the most meaningful datum.
SakeBomb Garage is offline
Old 12-06-2016, 09:40 AM
Sponsor
Cool to see another company making a lower mount. A shop in Japan (Creative Service Ohara) has something similar.
I would still recommend roll center adjusters in the rear though, especially if lowering the car more than 20mm.
Yeah we have seen those before but as they are in japan and not a big shop we were unable to find any information on them let alone attempt to order a set. Ours are made in the USA and readily available. Soon they will also be anodized the same Gold as well.
Although roll center adjuster will help lowering in the rear, they aren't really the tool for this job. They generally only lower the car by 12mm give or take where this provides up to 50mm for the best adjustment range possible. Also although RCAs help fix geometry from highly lowered cars, their job isn't to make the car highly lowered...
Old 12-07-2016, 09:31 AM
Sponsor
Only two left on the first run! Order quick!
SBG Billet Extended Lower Cup (S2000 Ohlins DFV Rear Ride Height Adjustment Kit)
Old 12-07-2016, 01:48 PM
Ricky_Flowers_'s Avatar
Hold it hold it hold it.......... 30mm of preload?!
Ricky_Flowers_ is offline
Old 12-07-2016, 02:19 PM
Sponsor
Depending on the spring rate yes absolutely. For a 7k (we don't recommend it but it can be done) spring which a decent number of people have used up to 30mm of preload is needed.
7k is approaching stock rear spring rate and the damper is much shorter stroke than the stock damper. Additionally the stock dampers have about 20mm of preload and are much longer stroke so it is not an unreasonable number.
We have had people come to us from other vendors with 7k springs who have terrible ride quality, after increasing preload to our recommended values it has been massively improved. With a 8k or less spring and 2mm of preload you are literally riding on the bumpstop 100% of the time. For more information about our preload recommendations check out our post on recommended preload settings here: https://www.s2ki.com/forums/s2000-br...nside-1166830/
Old 12-08-2016, 10:31 AM
Sponsor
Just one more left! Get yours today before the first production run is gone!
Old 12-08-2016, 04:31 PM
andrewhake's Avatar
Ah of course I was thinking of "shortest height" at shortest ride height instead of damper length. Thanks for the info.
What is the max longest damper length with the shorter lower mounts?
andrewhake is offline
Old 12-08-2016, 04:32 PM
andrewhake's Avatar
Yeah we have been unable to order a pair from them so far so great to see you guys providing a good solution.
Old 12-08-2016, 07:55 PM
Sponsor
Minimum possible damper free length is 378mm (32mm shorter than standard mount), max is 434mm. For reference the standard DFV at min length is 410mm. The billet lower mount can get above standard ride height with any spring rate.
Old 12-09-2016, 02:51 AM
andrewhake's Avatar
Again thanks for the info. How many threads engaged on that max free length measurement? Did you measure the max length with standard mount? (Just checked, looks like according to Ohlins the max recommended free length is ~435mm.)
Very cool that a shorter and higher ride height is actually possible compared to the standard mount. The design of the standard lower mount definitely leaves a lot of room for adjustment on the table with how much space there is between the actual mounting point (bolt holes) and the end of the threaded area. So this mount allows the actual damper body to get much closer to the mounting point itself.
Definitely post up once you have a sample of the anodized version!
SakeBomb Garage (12-12-2016)
Quick Reply: Öhlins DFV Billet Lower Mount - Fix Your Ride Height Issues!
