ABS light
#21
Originally Posted by Ajs_s2k,Feb 4 2009, 09:34 PM
Thanks Steve but i dont think you can do that on Uk cars only US and JDM, treasure island mate.
Guys, found out the code it was front drivers side wheel sensor. Will probably get a second hand one and smash the old one off and replace .
Tried the hard braking thing didnt work, but im sure the aint any air in system or the pedal would be funny.
Cheers
Cheers
My pedal was normal with the abs light on , sorry can't help anymore,hope it works out.
#22
Originally Posted by motogp1,Feb 4 2009, 10:42 PM
See my previous post aj , mine came up with a faulty rear sensor they reset it came back straight away. Replaced it still the same problem abs light on.
Thanks mate
#23
Originally Posted by Hypersonik,Feb 3 2009, 09:32 PM
Always amazes me this WRT the S2000
JDM has more power, comes with the half cloth seats, cleverer ECU (that you can remove without a silly tool)and will generally be in better condition than the UKDM equivalent.
Yet it's worth less (although negligible as you quite correctly state)?
Bonkers really.
Bonkers really.
#24
resurrection post mode on :-)
Adam, what happened finally? Was it only the sensor? My ABS light came on, did a check, rear right sensor not working. Just replaced it but ABS light still on...
Any help would be great
#25
I also would be interested i knowing what happened.
I have got an ABS light on at the moment in my 00 year s2k. I did the paper clip trick and its telling me that a rear right sensor is at fault. I did do a brake fluid change recently so I wonder if maybe its air in the system like previously suggested in the thread.
#26
Wow blast from the past, I'm pretty sure it was just a new sensor needed.
Remember it wont go off till you take it for a drive and hit speeds of 30 or above.
Cheers
Cheers
