Exhaust mod
Old 02-09-2015, 04:19 AM
  #1001
EdGoulden's Avatar
I have a 38mm I/D with test pipe... Sounds awesome apart from when you have a head to head with something faster, it sounds like you're trying too hard, but failing... Of course, only on track :S
Old 02-09-2015, 05:08 AM
  #1002
Daytona-Dave's Avatar
Originally Posted by earl's_f20c
Originally Posted by Mike's' timestamp='1423474923' post='23498878
Im still debating weather this will be to loud with the DMS Testpipe + 22mm ? andbody done this ?
One word....Bugle-y
is that a real word or have you just made it up
Old 02-09-2015, 05:09 AM
  #1003
Mike's's Avatar
One word....Bugle-y
I take that as in
Right-o, i guess im going to have to do this mod then when i come to putting it back together. (hurry up bushes)
Old 02-09-2015, 05:21 AM
  #1004
earl's_f20c's Avatar
Originally Posted by earl's_f20c' timestamp='1423485434' post='23498971
[quote name='Mike's' timestamp='1423474923' post='23498878']
One word....Bugle-y
I take that as in
[/quote]
Sorry Mikes that's a resounding no! I hated the zaust mod with a test pipe, the bugle sounds poop (IMO!) which is why I got a Berk HFC.
It's just about as good as you can get without replacing the OEM system
Old 02-09-2015, 07:11 AM
  #1005
not4s4l3's Avatar
Originally Posted by Fatbloke
Originally Posted by japcrap
Hi, Sorry, I know this is probably a stupid question but I got to page 4 and gave up looking for an answer. To do this mod, I understand you weld the pipe but do you drill holes in the exhaust at the pipe locations before you weld the pipe on? You must have to drill or cut a hole otherwise you would just be adding a pipe without an air path. Is thete a DIY for this anywhere?
Assuming you're in the Hants area as I think I read that you use TGM, Longlife in Basingstoke did my exhaust mod for £60. Well worth it to save you the hassle........
Cheers for the tip! I'm about an hours drive from Longlife..
Like japcrap, I don't mind a journey as well; if recommended by a member here.
Old 02-09-2015, 07:16 AM
  #1006
Mike's's Avatar
Ah ok glad i checked now im looking at more stuff to spend my wonga on.
Old 02-10-2015, 01:47 PM
  #1007
acid2000's Avatar
Mine is tegiwa test pipe with 20mm (i think) pipe mod the rest is standard. The 20mm means at low/crusing revs you hardly notice the noise at all but when you put your foot down it make a louder but not over the top noise but this i suppose its to personal preffrence im glad i didnt go larger as i don't want my eardrums vibrating at normal crusing speed but again to personal preffrence.
Old 02-12-2015, 12:56 AM
  #1008
Mike's's Avatar
Acid2000 - Could you make any sound clips ?
Old 02-12-2015, 02:11 AM
  #1009
not4s4l3's Avatar
Nice1 thanks for the tip; so I guess I'll go for 22mm being all stock with just a Berk HFC..
Old 02-12-2015, 02:12 AM
  #1010
not4s4l3's Avatar
That would be lovely if you can when you can!
Start up and a couple of 2nd and 3rd gear pulls will be really nice to listen to!
Quick Reply: Exhaust mod
