HEL Performance 2012 Time Attack Build
Old 11-02-2010, 02:52 PM
  #21
WinFreak's Avatar
Leave for good?
Old 11-02-2010, 11:05 PM
  #22
US NFR S2K's Avatar
Originally Posted by WinFreak,Nov 2 2010, 11:52 PM
Leave for good?
yep, pretty much. I'm hoping to stay overseas....Japan or Hawaii, I'm not quite ready to head back to the US.
Old 11-03-2010, 12:16 AM
  #23
Heinz '57's Avatar
Hard living!
Old 11-03-2010, 01:09 AM
  #24
US NFR S2K's Avatar
Originally Posted by Heinz '57,Nov 3 2010, 09:16 AM
Hard living!
Somebody has to do it....might as well be me
Old 11-03-2010, 02:24 AM
  #25
unclefester's Avatar
Is that the shell he had with the private plate? Looked straight on the ebay pictures.
Old 11-03-2010, 11:33 AM
  #26
HEL Performance's Avatar
Yes it is, and is perfectly straight. It had a bumper/wing ding but no structural damage at all, infact its very clean given how long its been sat.
Jobs being started today are pretty boring, but basically EVERYTHING is coming out ready to send it off for the cage to be done.
Heater and aircon weighs alot on its own!
Old 11-03-2010, 12:15 PM
  #27
s2konroids's Avatar
Great thread! , it will be most interesting to watch the transformation, J's/tracysports track cars are 'the' best IMO.
Could you please weight the whole air con system?
Cheers
Old 11-03-2010, 04:05 PM
  #28
Paul_J's Avatar
Awesome thread! can't wait to see progress.
I assume you've seen a lot of the ASM / J's Racing / Amuse S2000's from Japan?
Old 11-03-2010, 10:55 PM
  #29
Ultra_Nexus's Avatar
Should be interesting this.
Chassis wise, i'd like to see where you remove weight.
For me, the rear boot floor needs to be completely removed and replaced with a diffuser. You could go one stage further and have an exhaust blown jobbie too.
Doors/wings car be replaced with some vacuum formed plastic skins.
Real weigh can be removed from the suspension. All the arms are cast steel and are quite heavy. Porsche/VW (as i've been nosing around them recently) use cast aluminium. I'm sure that companies make aftermarket upper arms for the S2000, but not sure about lower. I'm sure you could fabricate pressed steel items though.
Staying with the suspension, the afore mentioned upper arm mounts wil need bracing. They did this on the 2004 model, but it'll need triangultion from each lug to chassis and not just a brace bar between the lugs.
Subframes are pressed steel, but have a lot of space so i'd seam weld, foam fill and have done with it, athough you can build in an elaborate cross brace design for them..
Old 11-04-2010, 01:21 AM
  #30
ge2
ge2's Avatar
What are the regs like?
Can you do all these things?
Quick Reply: HEL Performance 2012 Time Attack Build
