Official MoT Thread
Old 05-01-2015, 05:15 AM
  #21
Riknos's Avatar
Quick MOT question - headlamp washers - Fail if present and not working, what if they're removed but it's obvious it used to have them (hole in bumper) Is that a fail / advisory? Or fine?
Old 05-01-2015, 05:45 AM
  #22
mikefifth's Avatar
General consensus is:
If present they must work.
If not present then it doesn't matter.
Old 05-20-2015, 02:40 PM
  #23
Gaffa's Avatar
Mine went through the MOT ok today, only a minor hiccup, I had not checked to see if the Bridgestone's were directional and had not replaced the wheels on the same sides I removed them from, so uncannily both front and rears going in the wrong direction, doh !!
And just an advisory on a little surface corrosion on rear brake pipes.
Old 05-21-2015, 01:04 AM
  #24
Stevie_P's Avatar
Passed with no advisories.
Only ever had one advisory for rear pads getting low in the 5 years I've had it.
Mind you, it is an 05 with only 49,000 on the clock...
Old 05-22-2015, 12:59 AM
  #25
Mike's's Avatar
Passed about 3 weeks ago 2 advisory's low front pads and front brake hose clip was broke, was pleased with that.
Old 05-22-2015, 05:08 AM
  #26
jsh
jsh's Avatar
Passed this am . No advisories and still 4mm on the rear tyres after 15k miles
Goodyears last longer than Bridgestones .
Old 05-22-2015, 05:50 AM
  #27
Fatbloke's Avatar
Suggest you get your Vtec solenoid checked next time your near a workshop!
Old 05-22-2015, 05:58 AM
  #28
CHIPPO's Avatar
How do you get 15 out of tyres on an S, must have chauffeur the same as miss daisy
Old 05-22-2015, 06:35 AM
  #29
jsh
jsh's Avatar
Only managed 11k on MZ's
Nothing wrong with Vtec solenoid Works every time at least twice a year Sometimes 3 times during a Druid run .
Old 05-22-2015, 07:09 AM
  #30
Fatbloke's Avatar
Only managed 11k on MZ's <img src=/ponder2.gif' class='bbc_emoticon' alt='' />' /> Nothing wrong with Vtec solenoid <img src=/emot-tip-wink.gif' class='bbc_emoticon' alt='' />' /> Works every time at least twice a year <img src=/suspect.gif' class='bbc_emoticon' alt='' />' /> Sometimes 3 times during a Druid run . <img src=/driving.gif' class='bbc_emoticon' alt='' />' />
I managed 6k once. That set were definitely dry weather spec when they came off......
Quick Reply: Official MoT Thread
