Pulley Bearings
Old 04-29-2014, 12:36 PM
LiamR's Avatar
Default Pulley Bearings
Ok, so Ive been living with it for a few months now... A chirping noise as I plant my foot at around 2500-4000rpm.
Replaced the Serp belt (aux) and its still happening... Wobbled the pulleys and they seem to have quite a bit of play so its obviously the bearings.
Now I'm not one to scrimp and save, but my dad has just repaired his friends washer/dryer as it was making a grinding noise. He contacted Hotpoint who wanted £55 for the center bearing and housing.... he got the part number of the bearing, went on ebay... £3.50 and now its as good as new.
So does anyone know the size or have a part number of the bearings that are used in the tensioner and idler pulleys? Or has someone done a DIY bearing change themselves?
I have a hydraulic press etc for getting the bearings out so its not a problem on that side of things.
Thanks in advance,
Liam.
Old 04-29-2014, 02:03 PM
TonyDay90's Avatar
I like your thinking, might be worth asking on the main forum.
I dont know what the bearings are but when you start looking try http://www.bearingboys.co.uk/ good for any type of bearing you can think of.
If you find out what they are off the forum can you keep this updated as i need to do the same.
Old 04-29-2014, 02:08 PM
Theheff's Avatar
Is this for the belt tensioner pulley, if so I'd be interested in the part number also
Old 04-29-2014, 11:15 PM
BenRNBP's Avatar
I'm not sure where I got the info from but I have a bearing spec in my "useful car notes" of:
"6203 double sealed, high speed"
Might give you something to search on at least
Old 04-30-2014, 08:35 AM
TonyDay90's Avatar
Ben, is that for the pulley? or is just in your car notes as a random bearing, that may or may not be for the pulley?
Old 04-30-2014, 08:48 AM
LiamR's Avatar
Yes, its for both the tensioner and idler pulley.
Not sure if its the same bearing or different ones.
I will take a look and see if I can find it out
If worst comes to worst, Ill take the pulleys off and take them into a bearing shop
Theheff's Avatar
I found this
http://www.bearingboys.co.uk/6203-2R...earing-11494-p
17x40x12 is the measurement on there.
Anyone got one to hand that they can measure?
Old 04-30-2014, 09:01 AM
LiamR's Avatar
Ok, after some digging using Bens bearing number, I have found the correct bearing..
The tensioner pulley bearing is a 6203LHX3.
Hope this helps people
Old 04-30-2014, 09:25 AM
TonyDay90's Avatar
Have you ordered one Liam? let me know how you get on please.
Old 04-30-2014, 11:39 AM
BenRNBP's Avatar
The thread has moved on a little but yep for the tensioner pulley - not random listing of bearing
Quick Reply: Pulley Bearings
