Question regardless replacing lower suspension bushes.
I've bought powerflex bushes and mugen compliance bushes to replace the lower arms only.
None of my bushes are seized, can I use the existing bolts and nuts?
If nuts are nyloc I can just buy new nuts?
Thanks
Thanks
They are Specials,
have a deep area on them like the rears,
could re-use them if they look ok, just clean threads well with wire brush before removing.
Parts - 90362S2A000 - NUT, SELF-LOCK (12MM) (PFKL990847)
£8.35
Parts - 51393S2A020 - NUT, SELF-LOCK CAM (12MM) (PFKL651425)
£51.90
Yes special price too
ps these are front lower..
I've got the numbers thanks. I don't thank that answers my question can they definitely be reused or are they nyloc or other locking mechanism?
Thanks
Thanks
Nyloc"s type of fastener but with a recess on nut,
they are not a normal of the shelf nut.
I wouldn't be surprised if you were supposed to change the nuts once they have been removed? I plan on lock wiring mine for piece of mind....also subframe bolts as some of mine were finger tight when I removed my subframes.
