Relocating the Radio
#21
Thats a nice install,
I alwasy worry about putting tech like PC's into cars. Im an IT Engineer which puts me off, if only i could build a machine powerful enough to load the AEM software on its owns under a stripped down OS... now there is an idea!
#23
Not trying to argue, but I don't understand this comment. If I had to stare at the AF gauge the whole time I'm driving I think I'd go back to stock. In my experience the AF doesn't change much once the car is tuned, unless something breaks. My first S didn't even have a permanent AF gauge and I put 150k miles on the SC without any problems.
As for relocating the HU - I'm not aware of any ready-made extender wiring but you could make your own using Metra harnesses. I know the antenna wire runs along the passenger side of the transmission tunnel but I wouldn't bother messing with that. Just go directly to the antenna pre-amplifier box (in the trunk under the antenna), unplug the OEM antenna cable, and use a standard antenna extender cable to run to the new head unit location. My HU is currently in the trunk, in the spare tire area along with a small sub, and that's what I did.
#24
I'll have one sitting like this with two magnet vent holders.
#25
If the car's mapped properly you don't need to watch the AFR or any other mapped reading. It should only be checked every so offent if you think there is a problem.
IMO you do need to watch oil temp/pressure, coolant temp and possibly AIT. I keep an eye on these when on the track just to make sure I'm not overdoing things.
#26
#27
Flanders, just spent the last hour reading through your thread. Your car is mega, you should feel very proud!
I did look into the tablet thing a while back and may opt for it.
#28
I'm with you. Right now I have the oil temp/pressure and AFR temporarily installed where the radio belongs but I plan to move the 2 oil gauges into the OEM cluster and at that time the AFR goes back in the tool box. I don't track my car any more so I'm not concerned about IAT, but in my first S there was one particularly hot day at the track where IAT reached 199°. Might have been hotter, as that was the reading from the stock ECU and I wonder if the OBD output might be capped at 199. I know the ECT readings have big gaps at the upper range, jumping from 246° to 261° with nothing in-between, so it makes me wonder about how accurate the rest of the OBD signals are. As you'd expect, with those IATs the car ran very poorly, (ignition timing?), so I just stayed in the pits till the day cooled down.
OEM cluster?
#29
Purely as a matter of discussion, is there anything to improve reception of a smartphone - iWhipaerial or somesuch?
It's probably a Hertford problem (those ley lines that apparently keep the unique crows in the Royston triangle again!) but OutofTune Radio can be very spotty round these parts.
#30
Just had my radio out and measured it, the mechless compact radio is under half as big, it will be tight but the gauges should fit in front with a bit of jiggery pokery
