Technical FAQ v2.1
Old 04-27-2013, 03:46 AM
  #61
UK Moderator
lovegroova's Avatar
How to fix a not folding properly roof: https://www.s2ki.com/s2000/topic/101...how-to-fix-it/
Old 08-08-2013, 06:54 AM
  #62
bite me's Avatar
All the lucidauto links are now dead which looked like they would have been very useful.... any ideas?
Old 04-07-2014, 02:21 AM
  #63
ian_6301's Avatar
MY 2001 Alarm Fobs - square fob, 2x square buttons
I've just got off the phone from a very nice lady at Hamilton & Palmer, from whom I have just purchased a new key fob.
The alarm system is (funnily enough) no longer in production, but they are obliged to provide a supply of parts, pretty much in perpetuity. Unfortunately, they now have to outsource the production of small batches of these things, so the cost is now in the region of £54 per fob. Ouch.
The trick, so I'm told, is to always have a spare remote in hand and programmed. If you lose the one that works, you can't then "teach" the new fob. If you run out of working remotes, it's a whole other ball game.
Contact details:
Website - http://www.hamilton-palmer.co.uk/ But tbh, all it has on it that's of use is their phone number...
Phone - +44 (0)1732 760022
Mods, if this is perceived as naughty, posting links and phone numbers to the OEM supplier of alarms, please feel free to remove the contact details, but the rest might be of use, so please can we keep it? Much Ta.
Old 08-30-2014, 07:37 AM
  #64
Anfrax666's Avatar
Not sure if one for forum favourites or here but after scrolling through pages of info on Anti Roll Bars I stumbled across this:
Originally Posted by Shopman
FWIW you could source early OEM ones from a breakers.
The MY 2000 used a front 28.2 5mm thickness bar compared to a MY 2004 26.5mm 4.5 mm thickness.
year front----------------rear
2000 51300-S2A-003 52300-S2A-013 28.2MMXT5.0 27.2MMXT5.3
2002 51300-S2A-013 52300-S2A-J01 26.5MMXT4.5 27.2MMX4.5T
2004 51300-S2A-023 52300-S2A-J02 26.5MMXT4.5 25.4MMX4.5*
2006 51300-S2A-023 52300-S2A-J02 26.5MMXT4.5 25.4MMX4.5*
*according to press release.
you can reference the part numbers, the thickness is in the description.
Originally Posted by MB
Oops I was looking at the wrong numbers
If the below are correct, id actually be going for an 00 / CR front and keep the stadard rear or CR rear, combined with 8kg springs.
[CODE] | Front Rear | Front Rear
Model Year | Spring Spring | Sway Bar Sway Bar
2000-2001 | 219 291 | 393 427
2002-2003 | 246 309 | 300 396
2004-2005 | 262 278 | 300 311
2006-2007 | 262 269 | 300 311
2008-2009 | 280 294 | 354 311
2008-2009 CR | 384 343 | 392 362
Note 1: All figures are in lb/in. Divide by 56 to get kg/mm.Note 2: Edited 17Nov2010 with slight updates to spring rates per rev1 of paper
I was searching for the diameter of front & rear for each year as I needed to know what bush size to order to from Powerflex which list size options but not years. Could be handy for those with sized bolts/bushes after a polybush overhaul or general chassis tuneup
Old 05-13-2015, 01:39 PM
  #65
SteelCoyote's Avatar
Originally Posted by Bassoctopus
Hardtop Fitting Kit Details
The hardtop will not fit on to an S2000 without a fitting kit. Please factor in the cost of a fitting kit if you are buying a second hand hardtop.
Taken from this: http://www.handa-acc...000/s2k2top.pdf - fitting instructions & parts list, this is what is needed for a Hardtop fitting kit for an 02
- the left body side catcher
- the right body side catcher
- left side trim brush (optional, you can modify if you want - easy to get though)
- right side trim brush (optional, you can modify if you want - easy to get though)
- 2 front strikers (just to make sure that they're steel, & strong enough & they are cheaper than the uk)
- rear defroster switch
- Sub-harness
- 4 bolts 6x18mm
- 4 bolts 8x20mm
- 2 Rubber spacers
- 4 cushion spacers
- rear defroster relay
- 4 cushion tapes
Hardtop Fitting Instructions
Service Bulletins are issued by Honda to their dealer and service network to advise them of technical issues and resolutions. Most of the service bulletins concern service and maintenance proceedures, test equipment and so forth but some are related to specific vehicle problems and resolutions. [/size][/size][/font]
N00b here with a 2000 S2000, and I do not care about using/having the defrost--what of the above will I need/not need. My car already has the upgraded HT Strikers as they did that for the Softtop wind noise issue.
TYIA.
Old 07-14-2015, 07:00 AM
  #66
S2KIP's Avatar
Then you need the following:
View my build thread in my sig as I have pics of the process.
Old 09-09-2015, 01:43 AM
  #67
S2KIP's Avatar
Unless I'm missing something, there's no TCT issues listed in this thread? Perhaps something that could be incorporated?
Old 10-14-2015, 05:49 AM
  #68
heymynameismark's Avatar
Looking for NTN wheel bearings (as is OE Honda fitment).
Instead of the £100 Honda are looking for these days (bearing alone I might add), I found an NTN bearing, circlip and nut for £51 delivered.
http://simplybearings.co.uk/shop/p74...duct_info.html
RiddleMcFiddle
07-15-2009 12:59 PM
Bassoctopus
03-20-2005 08:22 AM
wrayr
10-03-2003 08:29 AM
wrayr
10-02-2003 08:56 PM
tuney
12-08-2000 05:10 PM
Quick Reply: Technical FAQ v2.1
