Toms S2K
#192
Hi mate, unless for looks I'd be tempted to leave the rears. I still use std rear calipers on mine, and had standard discs on for a good while too. I find it's a very front brake biased car. If you're struggling for rear bias you can go for a pad with a higher friction coefficient.
If you'd like brake parts, shoot us a PM.
SBG Competition Rear Brake System (S2000, Rear RX8 Caliper Retrofit kit) - SakeBomb Garage LLC
AP Competition Brake System (S2000) - SakeBomb Garage LLC
Wilwood Track-Day Brake System (S2000) - SakeBomb Garage LLC
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
#193
Our AP kit uses a 325x32mm rotor for better thermal management. The 28mm thick rotor never made sense to me personally... it's the same weight and less cooling. It's usually just used for packaging reasons. Also those rotors are straight slot, the J-hook has a higher initial bite and I'm not sure if those are fully floating or not... can't tell from the photo.
__________________
#194
As I am running 17" wheels, I was restricted in caliper choice, which in turn restricted my disc choice. I was going to go for 6 pot 330x32mm but wheel clearance was my issue
All in all, I am impressed with the setup as it deals with punishment a lot better than the DS2500/OEM setup I had before hand.
#195
Small update.
As with most aftermarket products, there will always be teething issues. Such is the case with the supercharger kit, the 25mm Kraftwerks recirc valve just can't cope or flow enough causing supercharger flutter. So, a few weeks later, with a revised intake to help lower intake temps and all fitment of a Turbosmart 50mm raceport BOV, she's running a lot better now!
A few pics of it installed along with freshly powder coated pipework done in Wrinkle Black.
Here's a small video of the sounds. No more flutter on gear change!
#197
Here is another UK based option for a relatively cheap AP based kit gor the S2000 :
Reyland Motorsport - tuning, rolling road, high performance brakes and Cosworth specialist - S2000
#198
#199
He still has stocks of the 5040 calliper, but when these are exhausted it will be replaced by the 9440, which is a direct replacement, but more expensive, so the price will then go up at that point.
#200
Looking back through your thread, i see that you under sealed the rear of your car, and then only around a year later your arches were ruined? were their signs of this while you were underselling or did it just seem to come all at once?
