Undersealing / Waxoyling
#22
This is my worst Nightmare :0... I shopped around everyone local to me and eventually decided to do it my self because i feared they would do exactly this... Trap in all the corrosion...
Id be getting the Wallpaper scraper out immediately if it were my car...
#24
I am in the process of getting mine done. I have also all the suspension arms and ARB sand blasted and power coated.
What do you recommend then for prevent rust and undercoat?
I have been told Kurust Rust remover is pretty good.. then any recommendation for a spray type undercoat protection? or is it better to use a brush?
#25
Cost me £60-100 all in all. But that is a terrible job!! Drilling holes!! Spraying everything!! For the price you paid i would of wanted all my panels removed, cleaned, rust removed, treated and then Wax Oyl'd.
Time consuming, but very rewarding
s2kii by Jake Baker, on Flickr
jshjf by Jake Baker, on Flickr
4794 by Jake Baker, on Flickr
bfkjsf by Jake Baker, on Flickr
abdd by Jake Baker, on Flickr
#26
#27
2016-07-29_08-27-36 by Jake Baker, on Flickr
diff by Jake Baker, on Flickr
abddddd by Jake Baker, on Flickr
s2kiiiiii by Jake Baker, on Flickr
1234 by Jake Baker, on Flickr
frames by Jake Baker, on Flickr
#28
This is why I did my own restoration work,I've heard all that I've got 50 years experiance and then did a crap job......ask to see pictures of previous work...... the rust has just been covered up in this case
Not to mention the pain in the butt when you need to work on it.
#29
Drilling holes to inject waxoyl is normal though the S2 has enough to negate the need.
Some of you chaps have done several days worth of labour there... nice work
#30
I hate you at the moment - the subframes, arms etc looks incredible!! Good work!
I used a few wire brush attachments to my angle grinder to get as much rust off as possible. Then coated the worst areas in Hammerite Krust (2 coats). On ebay you can get the large Wax Oyl spray cans (5 for £20-25 iirc) id use them rather than a brush type. Its much easier and a much nicer finish!
Also had all my arms, subframes, diff and hubs done aswell. So worth it! I never wanted a concourse car, just a clean track car, but once i started i couldnt stop painting things that looked crappy 2016-07-29_08-27-36 by Jake Baker, on Flickrdiff by Jake Baker, on Flickrabddddd by Jake Baker, on Flickrs2kiiiiii by Jake Baker, on Flickr1234 by Jake Baker, on Flickrframes by Jake Baker, on Flickr
[/quote]
Originally Posted by Jake89' timestamp='1476975409' post='24088399
[quote name='mantecosa' timestamp='1476968436' post='24088334']I am in the process of getting mine done. I have also all the suspension arms and ARB sand blasted and power coated. What do you recommend then for prevent rust and undercoat? I have been told Kurust Rust remover is pretty good.. then any recommendation for a spray type undercoat protection? or is it better to use a brush?
[/quote]
