What clutch and flywheel for a rotex supercharged s2000
Old 01-22-2017, 12:03 AM
Aaron B's Avatar
Default What clutch and flywheel for a rotex supercharged s2000
Hi all only me again. Clutch is slipping on my car. Apprantly it has a toda clutch and flywheel but it's slipping at about 4000 rpm. I'm looking at a stage 2 competition clutch and new flywheel. Any good? Any help will be much appreciated as I'm new to the s2000. Regards Aaron
Old 01-22-2017, 01:58 AM
johnckeen's Avatar
I kept my standard one in when I fitted my hks unit, hasn't slipped yet!
Old 01-22-2017, 02:04 AM
Toms1989's Avatar
I run competition clutch stage 2 in mine at 426bhp and 269ft lb.
Pedal feels like OEM but a lot more grabbier, Didn't opt for a flywheel as was told by many the gains are negligible and they're not quite as nice to drive with in traffic.
Old 01-22-2017, 04:00 AM
chrispayze's Avatar
Same here, CC S2. Slightly lighter than OEM, but definitely grabbier. Still smooth though. I found it juddered a little for the first few hundred miles, but once worn in, a few fairly 'heavy footed' starts and it smoothed out.
Old 01-22-2017, 04:02 AM
Aaron B's Avatar
Sounds like the clutch to go for. Are you also running standard flywheel? Also what is the clutch delay valve delete?
Old 01-22-2017, 07:33 AM
s2konroids's Avatar
Act organic is the best, have a read on here.
I have one for sale too.
Old 01-22-2017, 10:48 AM
Aaron B's Avatar
Hi is the clutch a new one? Any pics?
Old 01-23-2017, 03:04 AM
s2konroids's Avatar
Hi Aaron,
Can't seem to pm you?
Thanks
Old 01-23-2017, 03:38 AM
eSeM's Avatar
I am using an ACT 'street' clutch and OEM flywheel. Never had a problem with them.
This setup is generally regarded as the closest you can get to the OEM clutch feel.
Old 01-23-2017, 04:06 AM
surfer_crx's Avatar
I had a comp clutch stage 2 and can highly recommend them.
Quick Reply: What clutch and flywheel for a rotex supercharged s2000
