What ecu am I running? Rotrex supercharged 2005
Old 02-12-2017, 12:04 PM
Aaron B's Avatar
Default What ecu am I running? Rotrex supercharged 2005
Hi all. Need help, I done some investigating earlier and found a arm fuel and ingnition controller under neath the passenger side. I thought that the I would be running a aem fc ecu that replaces the standard Honda ecu? As with a supercharged you need to adjust bosst pressure and map the cars timing. I want to gather live data in order to check oil and boost pressure on and off track. So I bought a one reader that works with android. How can I tell if I have a aem ecu?
Old 02-12-2017, 12:11 PM
chrispayze's Avatar
Pull the trim off the passenger footwell, the door side. The ECU is under there. It'll say AEM on it if it is.
Aaron B's Avatar
Found this AEM FIC 6 ECU - Garage Whifbitz so looks like I have the standard Honda ecu and this piggy backs to it. So the android tablet I have bought with this Torque Pro Elm 327 [ Android ONLY ] [ V1.5 ] OBDII OBD 2 Bluetooth Fault Code Reader - Track Recorder Camera Accessory
Amazon Amazon
means i I can still collect live data from the obd reader
Old 02-12-2017, 12:15 PM
Aaron B's Avatar
Cheers for reply. I will pul trim of tomorrow and have a look. I recon I have the standard Honda ecu and the aem fic 6 ecu piggy backs to the standard ecu. Meaning I should be able to collect data from the obd port via that adapter I have bought
Old 02-12-2017, 12:17 PM
Aaron B's Avatar
The standard ecu must be fully mappable then. The aem fuel and ingnition controller must just fine line that area
Old 02-13-2017, 01:11 AM
mikefifth's Avatar
Talking
Sure about that?
Old 02-13-2017, 01:15 AM
Aaron B's Avatar
Not a clue! I will do some more investigating and report back. It must have a aem ecu
Old 02-13-2017, 04:03 AM
CynicG's Avatar
I'd be surprised if it was the oem ecu as it's not mappable. Even the Spoon ecu replacement was not mappable.
Aaron, I don't wish to be rude but did you ask any questions about this car before purchasing it?
Old 02-13-2017, 04:05 AM
Aaron B's Avatar
Hi pal thanks for reply. I asked a lot of questions but the chap bought it of his brother and did not have a clue about the car!
Aaron B's Avatar
I must have a upgraded ecu
Quick Reply: What ecu am I running? Rotrex supercharged 2005
