View Poll Results: What grade oil do you use?
0W/40
5.88%
5W/40
54.41%
10W/40
18.38%
5/30W
13.24%
Other
3.68%
Don't know
2.94%
Don't care
1.47%
Voters: 136. You may not vote on this poll
Old 02-13-2010, 03:46 AM
energetic's Avatar
Honda 5W-40 for me.
Old 02-13-2010, 06:10 AM
Paul_J's Avatar
hmm... I'm using 5w-30...
anyone tell me what the difference is?
Should I switch to 5w-40?
Doesn't it mean it's thicker when heated up? or is it that the 40 is thicker when cold?
Old 02-13-2010, 11:15 AM
martin j's Avatar
I have a supply of 0-40 mobil left so that's what it'll get at the first service unless I use it before then, if I have to get oil I'm gonna give the edge t/diesel stuff a try, it's been well recommended and I can get it at a discount from work.
Should I let them change the oil at the first service if I haven't reached the correct mileage by then?. I've done 3.2k but might manage 5k by then.
Old 02-13-2010, 11:22 AM
m1bjr's Avatar
Other way around.
Small number is viscosity when cold.
A 0W is thinner than a 10W at a given ambient temperature for example.
The upper number is viscosity at high temperature, and the reverse is true.
So a 50 will still be still thicker than a 30 at the high temp end.
Too thin and I guess it gets burned up in a 'lose' engine.
So if you expect REALLy high temps, go for a 40/50.
If you live in the arctic, go for a 0W-xx
I'm sure a 15W-xx would be fine in our moderate winters.
Its a little thicker when cold, sure, so may need a bit more cranking
Old 02-13-2010, 12:27 PM
integra_man's Avatar
I don't really know. Between services my car seems to synthesise its own oil.
I have a completely unused tub of 5W40 FWIW.
Old 02-13-2010, 01:08 PM
Riverside Red's Avatar
Silkolene Pro-s 5w 40
Old 02-13-2010, 02:46 PM
andy_intel's Avatar
Motul 300V Power 10w40 at the moment. Comes out almost as clean as it went in, and smells really good too. Never used anything better...
Old 02-13-2010, 02:49 PM
Phil_D's Avatar
Sunoco 10w - 60 fully syn simply because I tend to drive it like I stole it.
Old 02-13-2010, 02:51 PM
Paul_J's Avatar
Originally Posted by m1bjr,Feb 13 2010, 12:22 PM
Other way around.
Interesting. So it's better for me to use a xx/40 on track?
Old 02-13-2010, 03:55 PM
Si2k's Avatar
Oil is supposed to get dirty, it means the dirt is going into the oil and not staying in the engine. Motul 300V is a race oil where engine cleanliness isn't the top of it's priorities, obviously a nice smelling oil is important though.
Honda UK recommend a 5W-40 C3 oil.
Quick Reply: What grade oil do you use?
