windscreen washer motor
The windscreen washers don't work so guess its fuse or motor. ( yes I have checked there is liquid in there!!! )
Seeing as the washer bottle seems to be embedded is it an easy a job change? and more importantly, how the hell do you get to it? maybe I just need to wiggle/wd40 the wiring.
any idea which fuse it is - cant currently locate my handbook
thanks in advance.
thanks in advance.
Can you hear the pump running? I ask as I once managed to trap the hose in the bonnet hinge, so the pump,ran but I got no water from the jets.
If not, the fuse is number 2 under the dash
