HEL Performance S2000 Oil Cooler Kit
#23
Here's a mini review and guide to the Oil Cooler Kit and Fitment. I intend to post a more detailed thread on the installation at some point in the future which I will link to here when its done, but in the mean time this is what you need to know.
Reason for installing the oil cooler was that I had previously seen oil temperatures as measured at the filter (post OEM cooler) of over 130 Deg. For example, one lap of the ring = 130-35 Deg Oil by the end of the lap. With another trip planned, I wanted to do something about this.
Not knowing the amount of cooling that would be provided, I decided that I would cut out the false vent on the drivers side and attach the cooler and brackets in such a way that I could make a baffle that would direct the air into the cooler.
As part of the install I moved my temp measurement from the filter sandwich plate to the sump plug (at least for the time being). After the install I did a test run with the vent open but before fitting the baffle. Temperatures never got above 85 around the roads/motorways (thats down 10-20 degs on normal).
As such plans changed a little and I did not bother with the baffle plate for the final install. In addition I also made a blanking plate so that I could remove the airflow into the compartment as overcooling was a possibility when not pushing it.
End result was that I drove to Germany and the Nurburgring (including Autobarns at speed) with the false vent covered, and oil temps were not a problem. 100DegC or less.
On the Ring I completed a lap with the vent still covered and my oil temperature was just above 120 DegC by the end - so over a 10DegC imprvement just with the cooler and no airflow.
I then removed the blanking plate and allowed the vent to flow air. Temperatures reduced by a futher 10DegC, seeing 110DegC max even with improving lap speeds.
So, happy with result!
Here are a few pictures:
Thermostatic Sandwich Plate, Aeroquip Hoses and fittings. (Hoses/fittings are cut to size and assembled yourself - however HEL can do this if required)
Sandwich Plate installed
Cooler Position (options limited by Charge Air hose to the right)
Note that the smaller brakets above the cooler were not actually nessecary as they we intened to mount the baffle I didn't use
Cut vent, and optional Blanking Plate (+Mikeys Grills).
Brackets we all made from 1/4" aluminium Angle - Making these is the most time consuming bit. Note that the shape of the angles is probably more complex than it needs to be as I wanted them to be flush with the front to be able to fit the Baffle I didn't use! (Small brackets also not required!)
This is how it sits in the Bumper, so you can see its position relative to the vent
This was the intended baffle arrangement that I didn't need
Will flesh out the actual install details when I can.
Gavin
Gavin
#24
#26
Originally Posted by HEL Performance' timestamp='1314350922' post='20915575
Full fitment/review coming from Gav B and following this we'll look to put an S2Ki offer on for it.
Hi HEL,
I would like to somewhat copy GavB's setup.
Could you price me this up please and get back to me on here or PM.
Many thanks
No problem, can supply like this anytime, although the bracketry isnt something we can supply as Gav created these himself.
#30
