Tegiwa Hubcentric Wheel Spacers 15 & 20mm - S2KI Honda S2000 Forums
Old 02-09-2015, 05:45 AM   #1
UK Trader
Tegiwa Imports's Avatar
Default Tegiwa Hubcentric Wheel Spacers 15 & 20mm
Not sure if you guys know we do these for the S2000…
TEGIWA Wheel Spacers. These hubcentric kits are without doubt, the finest on the market. Manufactured from billet aluminium and then anodized satin black for a subtle and durable finish. When fitted they will not only enhance the appearance but improve the stability of your vehicle. Whether you want to fill out the gap between tyre and arch or increase your track width these spacers are the perfect solution. Available in both 15mm and 20mm width in a 4x100 or 5x114 PCD. Supplied complete with all fixings for a 'bolt-on' easy installation. Sold in pairs.
S2000 FRONTS (15mm only)
http://www.tegiwaimports.com/select-...000-front.html
S2000 REARS (15 or 20mm)
http://www.tegiwaimports.com/select-...100-5x114.html
Thanks
TEGIWA
Tegiwa Imports is offline   Reply With Quote
Old 02-10-2015, 03:52 AM   #2
Member
bobonacus's Avatar
I can certainly vouch for the quality of these spacers, perfect fit, fitted 15mm to mine last week (so I could fit the Spoon 4 pots with standard AP1 wheels). Only think to note is you will need to chop off about 10mm of the original wheel studs as they protrude into the wheel
Glad you've split out the front and rears, much easier
bobonacus is offline   Reply With Quote
Old 02-12-2015, 03:03 AM   #3
UK Trader
Thanks for the feedback!
Old 01-17-2017, 09:06 AM   #4
SCZ4's Avatar
Anyone else fitted these?
Did you need to cut the original studs with 17" OEM wheels.
Seems to be conflicting information on this. I'm specifically interested in 15mm rears.
SCZ4 is offline   Reply With Quote
Old 01-17-2017, 05:03 PM   #5
Babonacas does Say cut 10mm off studs.
noodels is offline   Reply With Quote
Old 01-29-2017, 08:43 PM   #6
Can anyone else offer any more experience of these? The whole "easy installation" doesn't really go with having to cut off some of the studs.
I'm interested in them but if I have to cut the studs then the idea will be binned.
​​​​​​​Thanks.
FrontRowForward is offline   Reply With Quote
Old 01-30-2017, 03:08 AM   #7
He was on 16" pre-facelift wheels though .
The V1 17s have a cut out in the back that I "believe" the OE studs may fit in (as I have seen similar spacers on US cars that fitted the 17" wheels without mods).
However, if you have an aftermarket wheel without the deep recesses, then you will have to cut the OE studs down.
Mike RT4 is offline   Reply With Quote
Old 01-30-2017, 12:10 PM   #8
SCZ4's Avatar
I removed my wheels tonight and my V1 17's do indeed have a very deep recess, so I think I would potentially be ok.
I think 15mm would be plenty for the rear, no need to roll arches. But what about 15mm at the front? Would they rub? I have Eibachs fitted.
Old 01-30-2017, 12:53 PM   #9
I've just fitted H&R 15mm spacers all round with the OEM 8.5" rears on the front with 245/40 AD08s, my suspension is set to 635mm from ground to top of the arch and I only get slight touching on big compressions (I'm going to raise it to 640). Measure your ride height and if you are above this, you will be fine with the standard size fronts .
The rears are at 655mm and are fine .
Old 01-30-2017, 12:57 PM   #10
SCZ4's Avatar
Were the H&R spacers bolt on? Or did you install extended studs?
I don't see 15mm H&R bolt-ons
https://www.dcperformance.co.uk/upra...nda/s2000.html
Thread Thread Starter Forum Replies Last Post
Wheel clearance requirements for BBK elna9ry S2000 Modifications and Parts 1 11-09-2016 08:27 AM
SumoSpeed February Feature Black Nugget The S2000 Gallery 31 02-19-2010 10:55 AM
WTB :: H&R or Ichiba 20mm wheel spacer unethikl Want to Buy 3 02-12-2010 11:47 AM
WTB: 20mm and 25mm wheel spacers SKYHUNTER143rd Want to Buy 2 12-14-2009 01:47 PM
Spacers SOLD! j0nathanl3e Member S2000 Classifieds and For Sale 12 06-26-2008 12:51 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
