Downforce front fenders max fitment
#21
Not a good angle, but running downforce front fenders with ccw 18x10.5 with 70/50 offset rear/front. 285/30/18 advan neova ad08. haven't had it corner balanced and aligned with the new setup so ride heights are a little off, as well as camber. Fronts rub at the last 5 or so % of full lock. I have more pictures, but am not able to find them atm. I'll post when I get more
#22
Do you have BBK clearance up front?
#23
There is still another 10-12mm outer and inner fitment to play with all the way around. If you want to get specific for best fitment on 11's, you want 11 +63 rear, and 11" +42 front with +30mm DF fenders. 285's
#24
See this thread - on stock fenders.
https://www.s2ki.com/s2000/topic/624...air-c10-notes/
You should be able to get more under there with DF fenders.
#25
s2000 junky is pretty spot on, about 10ish mm more. This is good for me as I plan to run 8-10mm spacers since I plan to run the 6/4 stoptech kit and don't think they'd clear currently. Running their st-40 328x28 kit up front and they barely clear with no spacer. and for clarification on initial post, since I didn't specify, I meant rubbing on front on inner control arm.
#26
#27
Yep pretty much, 11" +40 is the offset you need for a 30mm downforce front fender and a 285 fitment. 295 would be super tight and may cause some rubbing in or out depending on your ride height and alignment. Obviously you don’t want to set alignment for fitment, you want to set alignment for best chassis tuning.
Going to be quite a track width difference running 60mm total up front compared to the rear. It will look and handle a bit funny. Your better option would be to run over fenders in the rear and push the track width out to more closely match the front. If anything a slightly wider rear track width is preferred for added stability on this car at speed. If you want to maximize the available fender opening on this car, your going to end up with a staggered fitment anyway, and that’s ok, doesn’t mean it will perform any less then a square, in many ways its a better handling set up anyway and yoru maximizing the total grip level of the car. I run 255/295 stagger on stock/modded fenders and feel its pretty optimum. If I were going with wide body/over fenders, Id widen the tires and or track width, but keep the same stagger percentage between front/rear. Depends on the driving environment you will be tuning your suspension for though, as well as driver preference.
#28
I just fitted a new tire set up this winter btw, 275/4017-315/35/17 stagger. Still "stock" fenders. Same 10"/11.5" wheels I ran the old 255/295's on. There wasn't much wiggle room left at all on my fenders, but with a little pulling, messaging, trimming and slight suspension height adjustment to compensate for the slightly taller tire diameter, I was able to pack them in. The additional widths were not much, as the XS ran wide for their sizes and the NT05 run narrow. So I pretty much split the difference on the up size which made this feasible feat to try.
