Enkei Rpf1 question
Old 10-15-2016, 12:53 AM
Diegogoesslow's Avatar
Default Enkei Rpf1 question
Hi guys just bought my s2000 and I have a set of rpf1 17x9 +35 from my civic that I want to put on the s2000 and I'm wondering if anyone ever tried this setup?
Right now it's on stock height but I'm planning on lowering it soon.
Thank you
Old 10-15-2016, 05:00 AM
Chuck S's Avatar
Received 1,128 Likes on 991 Posts
Jack up the car and try them!
-- Chuck
Old 10-15-2016, 06:44 AM
Lawrenceh's Avatar
It seems like the offset could be a problem..
Old 10-15-2016, 07:17 AM
1nate7's Avatar
Not a good fit. You can MAKE them work with a combination of stretched tires, negative camber, and rolled fenders. Considering how cheap and common this wheel is, I'd highly recommend selling them and getting +45 instead. That isn't a knock on the wheel either, currently running a set myself. +35 would stick out additional 10mm compared to this:
Old 10-16-2016, 12:51 PM
riceball777's Avatar
I would not run them. I have rpf1 in 17x9+45 with a 255/40/17 in the front are in my opinion they are too aggressive. I'm all about function and they simply stick out too much for stock front fenders that are rolled flat. I had to run -2.5 camber in the front to just barely clear so that it does not rub when hitting big bumps and dips on the road. The real problems is going up driveways. If the wheel is turned a lot and you try to go up a drive way it will murder the fenders. I already cracked my passenger stock fender because of this and your rims will even stick out another 10mm more than mine. You can make them work is you want to run over -3 degrees of camber and stretch super narrow 215 tires on the rims but that would just ruin the car and would just be stupid.
Old 10-16-2016, 01:26 PM
Gotcha, thx guys I'll just go head and sell them
Old 12-21-2016, 03:52 PM
denlin68's Avatar
what if i run 17x9 +45 with 225/45 tires stock height in the front of the car, would that still rub the fender lining ?
Old 12-22-2016, 08:22 AM
Site Moderator
Manga_Spawn's Avatar
You would still need to roll the fenders with 17x9 +45. At stock height it may never rub but there is still a chance. It will also look terrible.
Rozar
12-03-2014 04:29 AM
NoLogix
11-23-2013 07:12 AM
dangthamang
06-25-2012 07:06 PM
cpx3mbp
03-05-2011 10:12 PM
Aze85
02-27-2008 12:03 AM
Quick Reply: Enkei Rpf1 question
