NOTICE: Correct Rear Tire Size AP1
#441
Originally Posted by SSM*03*S2K,Feb 3 2010, 10:29 AM
when searching for tires, make sure to research the tread width of the tire you are comparing, be it 225 or 245 and try to be as close to 8.5" tread width as possible. there are some 225 tires that have close to 8.5" tread width like our s02's but most 245's are all 8.5" which is why 245's are recommended. if it was me i wouldnt even consider a tire that is under a 8.25" tread width be it 225 or 245. people get too hung up on the 225 vs 245 debate. a 225 tire with a 8.5" tread width is the same as a 245 tire with a 8.5" tread width.
For sure, NO ONE should be insisting on 245/45-16 for the rear tires. There are only small number of tires still available in 245/45-16, and they're not the best you can get within a given category. IMO, this stickie should go bye-bye, as all it does now is encourage people to buy inferior tires. STILL hear people commenting on how AP1 owners MUST go with 245/45-16 rears.
But I also say don't get too hung up on tread width dimensions for 225s either. Get the best tire for your wants/needs usage and don't worry about it.
Fwiw, I've run treadwidth staggers ranging from 0.5" to 1.5" on my stock AP1 at the track, handling balance is affected, but not by a tremendous amount. Overall handling demeanor is similar (i.e., if the back end starts to feel loose and you lift off the gas, the AP1 absolutely WILL bite, whatever the treadwidth stagger is!) On the street with street tires, I believe that outright treadwidth is going to affect balance even less.
Die stickie die...
#442
I find myself reading this thread over & over again.. WTF right? First it was not good, then it is now. I'm going with 225/50/16s & saving myself the freaking headache. Or I'll just get 17s & get rid of the 16s all together because its way too much hassle.
#443
I need new rear tires for my 2003 AP1 with stock rims, I'm going with tire size 225/50-16 and would like to keep my tread width as close to 8.5 as possible.
My car is a daily driver and although she will never see a track, I do drive aggressive on pot-holed ridden NYC streets (reason I'm afraid to plus size my rims).
I'm looking for the best bang for my buck. I never drive in snow but do drive in cold weather.
Here are some I've discovered so far:
Bridgestone Potenza RE-11
Dunlop Direzza Sport Z1 Star Spec
Bridgestone Potenza RE760 Sport
Yokohama S.drive
Yokohama ADVAN Neova AD08
What would you recommend? Are there any other tires I should be looking into
Yokohama S.drive
#444
I would recommend the Dunlop Direzza Z1 Star Specs all day, everyday. I can attest to the claims of their performance in dry and wet conditions. The price is great in that respect as well. If treadwear isn't your biggest concern(as if it should owning an S2k) then by all mean try them. I'm on my second set of rears after the first lasted a little over 14k mi.
#446
Don't be too fixated on "tread width"! Particularly on the street, the importance of this dimension is often overestimated.
Die stickie die...
Die stickie die...
