TPMS... What are my options
#21
Build a tube out of PVC pipe, attach a bicycle valve to it somewhere. Take all 4 TMPS units and put them in the tube. Seal it up, and pump it up to 32psi. Attach the pressurized tube to the car somewhere out of the way, and you'll never have a problem.
#22
Yeah, I don't think my car would pass inspection down here with the TPMS light on. I might just hold onto my OEM wheels and throw them back on when the time comes. If I were to drive around for a while with aftermarket wheels and no sensors and the TPMS light on, would the light reset once I put the original wheels back on? The GC07C was discontinued about 5-6 years ago, very hard to come by nowadays.
That's a pipe bomb, does not work on the s2000. I wish it did because I would have done that.
#23
#25
Here are my thoughts on the TPMS:
Keep them functional because I have gotten a slow leak before and the TPMS saved me from driving really far from home with a nail in my tire
if you take the sensors out the TMPS light will be off at first but come on when you have driven for about 20 miles and stay on
also if your tire pressure drops to about 26 psi the TMPS light will come on
THE best TPMS sensor for 08-09 S2000 is the VDO Redi-sensor part number SE10002 only about $40 each
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
I have confirmed that this sensor works flawlessly with the S2000 TPMS
High OEM quality aluminum stem construction, way less than Honda sensors, multi-angled so they fit many wheels, very lightweight and easy to program.
They just work. I put the same exact sensors in my Volk C345UL's
MAKE SURE to torque them down to only 71 INCH LBS.!!!!
I do have a professional TPMS programmer the ATEQ-VT55 which is $$$$ but any good tire shop can program them for a $$ fee
Once programmed the TPMS light will stay lit but just drive around to 30 mph and it will turn off.
VSA will engage even with the TPMS light on
TPMS pipe bomb for the S2000 is a dumb idea and waste of money
#26
For those who don't know, RylisPro was the one who help me out a lot when I was trying to figure this out for my own car, thanks bro.
So are those REDI sensors the real deal, I know they were just coming out when you and I were PMing. I know a lot of these sensors work well with volk wheels, but I wonder if they will fit in other wheels like the Enki RFP1.
#27
Yes the Redi-Sensor SE10002 works well and is the real deal.
It is designed to be programmed by many popular TPMS re-program tools such as the ATEQ-VT55, Snap-On TPMS3, Bartec TECH400SD etc.
basically any TPMS re-programmer that has OBDII capability to reprogram the S2000's ECU.
Most Honda, Toyota, etc. service dealers should have one as most Asian car manufacturers require OBDII port access in order to re-program their TPMS
The Redi-Sensor SE10002 should work with many wheels since it can be configured into different angles
the key is to have a brand new plastic seal which is shown in the service kit part number SE54190
If you buy four brand new SE10002 sensors it should have everything you need to install in your wheels
just make sure you have a good inch lbs. torque wrench
more info is here:
http://www.showmetheparts.com/vdo/
just look up 2008-09 Honda S2000
more info is here:
#28
Great info everyone! I'm thinking this thread should be stickied... Mods?
It's good to know that the car doesn't have to go to the dealer. Talked to a local performance shop that has done all my tire mounting in the past, but they only have a tool for German cars. Wondering if that tool would still work for an S2000. I would think OBDII would be the same for all cars, no?
#30
