CT ENGINEERING / COMPTECH PARTS
Go Tuning Unlimited is now an Authorized Dealer for CT Engineering / Comptech
PM FOR PRICING!
CT Engineering Supercharger Kit - Aftercooled for Honda S2000 00-09
If you are looking to transform your S2000, the CT Engineering After-Cooled Supercharger kits are a great start. Utilizing the benefits of a centrifugal supercharger, designed to match the factory power characteristics of the high revving Honda 2.0L and 2.2L power plants. The CT Engineering Supercharger kits will add more power to your S2000 at the higher RPM's, keeping the car drivable in traffic & day-to-day driving, but throttle the engine to redline & you'll feel the burst of acceleration from the additional 70-80 horsepower at the rear wheels. This base kit is CARB approved for street use in CA.
The kit includes the blower unit, icebox intake with a carbon fiber lid, all mounting brackets, fuel system upgrades (including an in tank Fuel Pump & CT Engineering FPR), all hoses & drive belt and the CT Engineering ACM unit with wiring harness. 310-320 horsepower at the crank. Utilizes a very efficient gear driven centrifugal supercharger and is a simple bolt on kit.
New 1220SL blower unit provides more efficent boost pressure, and the ability to increase power easily with additional upgrades.
Kit does not require that you bend or modify your vehicle to fit.
Cooler housing designed with popular blow-off valve bolt pattern on by-pass valve outlet, for those who want to run higher than standard boost levels. This kit is designed so that it can be removed without any modifications to the factory components.
Included After-cooler lowers inlet temps by 50-70 degrees F.
Highly efficient cooler unit losses less than 0.5psi boost.
After-cooled kits also include after-cooler, after-cooler radiator, water pump, and all necessary hardware.
Note: Warranty is void w/ higher than standard boost level.
Requires $200 for a core charge for the factory crank pulley, which will be refunded upon return of a undamaged stock crank pulley.
CT Engineering High Flow Air Intake Kit for Honda S2000 00-09
The CT Engineering Icebox Air Intake System is designed to pull inlet air from outside the engine compartment to ensure that denser cold air is actually getting to the engine. Our design also helps keep intake noise to a minimum. The kits use a foam filter that can be cleaned and reused.
NEW UPDATED BOX DESIGN
New box design allows for greater hood clearance and simple prop-rod install
Cold Air Intake with reusable two-stage foam filter element
Carbon fiber lid on air box
Will not ingest water
Slightly louder than stock
Air box suppresses noise from filter element
CARB legal for street use in California
Application: 00-09 Honda S2000
CT Engineering Air Filter Replacement for Intake Kit & OEM Replacement for Honda S2000 00-09
Application: S2000 Intake & S2000 Supercharger 00-09
Two-stage, hi-flow, "drop-in" filter upgrade
Includes filter, and inlet adapter
3hp gain at the wheels
CT Engineering also offers high flow foam air filters that are a direct replacement for the standard factory filter and can be cleaned and reused.
Shipping/Insurance Info:
- Shipping cost will be determined by location.
- Insurance will be included on all orders.
- Shipping to Canada, Hawaii, Alaska, or international. Please PM me for shipping quote.
- For local pick up please PM me. We are located in Orange County, CA.
- The product(s) will be very well packaged.
Payment Info:
- You can order by phone, email, PM, or through our website at gotuning.com
- We accept Visa, Mastercard, Discover, Paypal, Cash, Bank Cashier's Check.
- All order MUST be shipped to billing address or confirmed address for paypal.
- Paypal payments can be sent to paypal@gotuning.com.
- 8.75% Sales Tax sales tax is required for all sales within California.
PM FOR PRICING!
Payment Info:
