Yet Another E-Tune Review for Gernby
I'm not usually one for reviews, but it would be a crime to the community for not writing one up after the service I have received from Greg. Before I sent payment, he first informed me that his process is a bit different from most conventional tuners and that if the process didn't sound appealing, he would issue a full refund. During the whole process, he promptly responded to any questions I had and I never once felt like he was rushing to get my tune over with. On the contrary, I felt as though the car he was tuning was his own; he never hesitated to perform more iterations or provide more input. I truly feel that getting tuned by Greg is a great value-- the result is a smooth, optimized, and custom tune at a very, very competitive price. I highly recommend Greg to those that are on the fence about getting an e-tune or picking a tuner. However, his actual tuning process can get a bit tedious and nerve racking at times-- because of the specific process, there is a risk of getting pulled over- especially if you live in an area like I do (LA-- anal retentive popo).
Here is a dyno created by Gernby's own E-Dyno. I chose to do 1 stock run and 2 tuned runs so that I could overlay them on the same dyno sheet.
Mods: Hytech 3" Test Pipe + HKS 75mm Single
Red: 'Stock Tuned' Hondata map
Green: Tuned (Run 1)
Blue: Tuned (Run 2)
(Ignore the Black Line)
Blue: Tuned (Run 2)
Thanks for the feedback! You defnitely gained a lot in the midrange, but I sure hate looking at those outdated graphs fom that Excel Soft Dyno.
Here is what they look like on my current software. (which runs real-time, wirelessly while live tuning on my Surface Pro!)
Great results!
approximately how many WOT runs did you have to do? and what gear do they need to be done in? I can safely do 3rd gear pulls all day long. 4th gear and it starts to get harder to make sure I don't get caught.
3rd I can do all day long without too many issues. 4th gear starts to get way into reckless driving territory on the streets.
I imagine all of the pulls really need to be done on the same road under the same conditions?
In order to do these E tunes, is the only thing I need a flashpro? I have been considering getting an E tune once the weather breaks or possibly just driving out to Evans Tuning since it is not that far from me.
Most of your gains come from fixing the over-lean stock Hondata tune between 3.5-6k. This was causing some appreciable knock in that range, and hurt your power.
Looks like even the E-tune would do well with a little more fuel below 3.5k to fix the knock that is still occurring there.
The Hondata tune was clearly running lean, but that is a normal knock level. He's definitely not losing power due to knock, and his AFR's are fine with the new tune.
