Alignments in Worcester MA
If you haven't decided yet I can also help you out with your alignment, i work at Honda in auburn, flush to floor alignment rack also. Can do OEM or custom specs
Well thankfully honda made the s2000 so awesome you can adjust every alignment angle on the car so when you usually lower your car it throws the camber off and you can adjust it back to stock specs or for the fitment/Hellaflush people they can adjust the camber to as much negative as needed. So on this car you can adjust toe, caster and camber. On mostly every other car you can only adjust toe.
