Valve Adjustment
Old 08-27-2014, 07:55 PM
Smart_Patrol's Avatar
Default Valve Adjustment
Anyone in York County, Maine want to help me with adjusting my valves? I am in South Sanford. Beer is on me.,,,
Old 09-02-2014, 10:32 PM
Or know of a good shop to do this? Thanks.
Old 09-04-2014, 06:38 AM
IMP
IMP's Avatar
Take it to Scotty at Ballistic in Bow, NH (Concord area)?
Old 09-04-2014, 08:22 PM
Thanks for the recommendation, but that is 1.5 hours away. No one has any guys in Portland or Portsmouth?
Old 09-05-2014, 01:07 PM
pgss2k's Avatar
Its a valve adjustment, not rocket science. Any reputable place should be able to do it. I know we all don't want to trust it to just anyone but if you are not willing to learn how to do it or take it a ways away not sure what to say.
This is a good guide
http://robrobinette.com/S2000ValveAdjust.htm
There are vids on you tube too
Old 09-05-2014, 04:59 PM
Thanks for the guide. I contacted Ballistic Motorsports and think I will be doing this myself.
Old 09-09-2014, 09:10 AM
blueosprey90's Avatar
There are two threads on valve adjustment (probably including the one Paul posted) and one thread on the AP-1 valve retainers here. If you have the AP-1, it might be wise to check/replace the retainers
https://www.s2ki.com/s2000/topic/548...d-maintenance/
Old 09-10-2014, 06:58 PM
Thanks, I have an AP-2.
Old 09-11-2014, 12:27 PM
Car Analogy's Avatar
Received 1,315 Likes on 993 Posts
Here is my top tip on valve adjustments. A lot of guys mess it up due to complexity of aligning timing marks, etc. Wrong number of turns after lining up marks, etc. I say, forget the timing marks altogether. Instead, just turn engine until both cam lobes, intake and exhaust, are pointing UP for that cylinder (or as close to up as possible). Adjust valves for that cylinder. Rinse, lather, repeat.
You can't mess it up if you follow this method, and takes much less time.
Old 09-15-2014, 04:08 AM
AZfury's Avatar
I wouldn't do that, what I found to be way easier is to just stick a long screwdriver into the cylinder and turn the crank until you get top dead on the desired cylinder you are trying to adj for.
Quick Reply: Valve Adjustment
