Ottawa S2000 Owners Ottawa Canada and area
Suspect leaking in trunk
Old 12-10-2014, 06:55 AM
s20001320's Avatar
Default Suspect leaking in trunk
Hi Everyone,
I just bought an AP1, I'm not sure if this is normal or not but I found the jack and tool in the trunk are rusted. Would this be leaking from the softtop? or just aged? thank you.
Old 12-10-2014, 09:47 AM
Oyagi's Avatar
Welcome to the community.
If your tool kit is rusted, I'd pull up the carpet in the trunk and check for water damage. Softtop...perhaps. Could also be a leak in the trunk floor.
Old 12-10-2014, 10:19 AM
s20001320's Avatar
thank you, I'll look into it tonite, any suggestions for repair if there are water damage?
Old 01-03-2015, 11:58 AM
bottleboy's Avatar
https://www.s2ki.com/s2000/topic/465...trunk-picsfix/
this is a bad spot
Old 02-09-2015, 04:22 AM
starchland's Avatar
How is your soft spot? Possible it could be leaking from a bad soft top install where it meets the body, or if your plastic window is cracked. There are also drainage channels that could be overfilling. Pull out the carpet and see where it's coming in
patt_stayys2k
07-21-2017 08:46 AM
Charper732
05-31-2017 01:01 PM
S2KiLLa19
04-11-2016 08:42 AM
lolS2K
09-29-2015 08:16 AM
tlee1234
05-02-2009 07:12 AM
Quick Reply: Suspect leaking in trunk
