Side Strake Repair
Side Strake Repair
Hello!
So the previous owner installed the OEM Side Strake Kit and the person/dealership Drilled a hole through the rear wheel panel.
I can just install them back on the car but I like the looks of the car without them on, should I just leave them on or get the spots repaired from a body shop?
Anyone else had this problem or have a resolution from someone's mistake..
what color is the car?
You can get it fixed at a shop for an expensive price, or just get a sticker sheet close to the color of your car and get a 1 inch hole puncher and use the sticker for the hole. No one will notice!
Still wish they didnt drill a hole in the car.
Two choices, use a rubber or plastic grommet as a temporary fix to fill the hole. Preferable way would be to use a filler to repair the hole, and then try to paint to match.
The best way to repair the hole would be a weld, a cheaper alternative would be a metal mesh patch to attach the filler to.
ungucpho
08-02-2011 08:35 AM
