CNC Speedshop Ford 8.8” Differential Conversion Kit for the S2000
Banned
Introducing CNC Speedshop’s 8.8” rear end differential conversion kit for the S2000. This patent pending kit replaces the OEM Honda differential and axles with a Ford 8.8” differential and axles. The kit is the most complete on the market and requires no modification to the vehicle.
This kit has been specifically engineered to direct the driveline stresses in the same way that the OEM’s engineered the parts. This means the front mounts will not break off and the loads are distributed properly to the OEM s2000 bushing locations. The cradle and differential case have been designed to work together with the vehicle to ensure it can handle the abuse. Although we build our mounting cradles out of steel, as opposed to a weaker metal, the kit is only 15 lbs. heavier than the OEM parts that are being replaced.
The kit includes a brand new differential assembly. All new Ford differential case, cover, pinion flange and all new differential internals are assembled to spec by East Coast Gear Supply before arriving at your door. This means you won’t be digging around a junkyard, hoping you are able to find a used differential that fits and is in any sort of usable condition. Our differentials also come with a 5 year warranty.
We are offering two kits that cater to differing power levels.
Street Kit - Stage 1
Based on Ford 8.8 Ring/Pinion
No additional parts required - EVERYTHING included
5 Year Warranty on Differential - All parts NEW, assembled by ECGS
Yukon Gear Duragrip 2 way LSD
Lifetime warranty on mounting cradle
Equal Length DSS Level 2.9 “500hp” Axles - 1 Year Warranty
Completely bolt in
Utilizes stock driveshaft and hubs (not included)
Virtually any gear ratio available
All necessary fluids included
MSRP $4399
Introductory s2ki price $3999
Race Kit - Stage 2
Equal Length DSS Level 5.9 “1000hp” Axles with larger 33 spline outer joint and matching hubs
DSS One Piece Steel Driveshaft - Aluminum upgrade available.
MSRP $5899
Introductory s2ki Price $5499
We very highly recommend professional installation. Please note that care should be taken to lubricate assembly bolts to avoid differential bushing twist if you are retaining your stock bushings. While not necessary, removing the charcoal canister and exhaust during installation will make for a more efficient install process.
Custom colors are available for the differential mounting cradle. Please provide the powder coating color code when ordering. Please allow 14 days for building time as each differential is built to customer spec.
We are offering our introductory s2ki price to the first five kits that are sold. Discount only available through purchase via our website using coupon code s2kdiff.
CNCSpeedshop Race Diff kit
CNC Speedshop Street Diff kit
** See second post for pictures**
Central NC Speedshop
Zebulon NC, 27597
919-375-5036
sales@centralncspeedshop.com
Completely bolt in
MSRP $4399
Race Kit - Stage 2
MSRP $5899
Zebulon NC, 27597
919-375-5036
Quick update:
The kits have started selling! As a reminder, we are offering special introductory pricing on a limited number of kits. This pricing saves you $400 per conversion kit.
Check out our website to place your order using the coupon code "s2kdiff".
Central NC Speedshop Website
Currently, we only have 4 kits remaining at the introductory price!
Banned
Another update:
Currently, we only have 3 kits remaining at the introductory price!
