Car takes time starting up after stalling
Old 02-07-2015, 02:55 PM
kahn_v's Avatar
Default Car takes time starting up after stalling
Hey guys. Had a quick search and found others having similar problems. It's rather annoying. Have to turn the ignition on and then off once or twice until
I can start it up again. Why does this happen?
Thank you
Old 02-07-2015, 04:39 PM
MB
Member
MB's Avatar
Unburnt fuel still in the cylinders I'd guess. Injectors are still firing whilst the car is cutting out, which stops combusting. Start up and you have extra fuel in there hence it needs pumping out. My theory anyway.
Old 02-08-2015, 01:39 AM
markforrester99's Avatar
If you dont mind me asking how is the car stalling? Is it driver error or is the car struggling to idle properly?
I cant think of once in 2 and a half years of ownership that my S2000 has stalled on me. Its always very quick at recovering its idle speed. Even if your quite crap with the clutch it will recover from low idle speeds no problem.
Old 02-08-2015, 02:40 AM
kahn_v's Avatar
No it's driver error, for example very rarely if I stall
It whilst parking maybe the car won't start up immediately when I push the starter button. I have to switch off the ignition once or sometimes twice and then try again. Found it rather odd then read other s2000's have the same problem
Old 02-08-2015, 02:44 AM
jimmyb1978's Avatar
This happens to mine also on the rare occasion that I stall it. Glad it's not just mine
Old 02-08-2015, 02:48 AM
GreenmanS2000's Avatar
Is the car standard or does it have any modifications?
Old 02-08-2015, 05:04 AM
kahn_v's Avatar
It's got breathing mods and mapped on EMS. However it has done this before when it was standard too
Old 02-08-2015, 05:46 AM
MB
Member
MB's Avatar
It's nothing abnormal IMO, for the reasons in my 1st post.
EMS often makes it a bit worse depending how it's mapped.
Old 02-08-2015, 05:53 AM
kahn_v's Avatar
Yeah I'd go with your theory actually MB it makes sense.
Just annoying as I stalled in a car park the other day and was blocking traffic whilst trying to start up the engine again
Lol
Old 02-08-2015, 06:22 AM
The AEM is well known for taking longer to start so if on top of that the warm starting fuel map is abit off then that would make it worse to start.
Quick Reply: Car takes time starting up after stalling
