amuse r1 touge car wheel/tire specs?
i wanted to know what the specs were on the amuse r1. i'm trying to figure out how wide i should get my wheels and size tires to fit and i did like how the amuse looked and the videos on it seems like it performs awesome.
How old is the hot version? Was it the orange AP1/2 with the Amuse R1 front end and the silver CE's?
If so they are Titanium Silver Volk CE28's sized 17x9 +40 all around.
ok awesome. any idea on the tires? or do u have any tire recommendations? im planning to put kw v3s lowered a bit aswell
There are several threads on 17x9+40 ce's. I'd suggest using a google search because it brings up better results, but I'd check out those threads. If you're willing to do some negative camber and roll your fenders as flat as you can, then you can run 255 square.
For tires get something like RE11A's, AD08R's, or even the new RE71. If those are pricey then either get RS3's or RE050's.
To run 17x9+40 CE28's you need to roll your fenders flat and add camber - as in at least 3 degrees. If you are not wanting to do anything to your fenders, then I highly suggest getting the standard S2000 offset.
Originally Posted by samson123' timestamp='1429594396' post='23585523
[quote name='WhyW' timestamp='1429572235' post='23585115']
[/quote]
The standard offset would be less wide?
Originally Posted by WhyW' timestamp='1429607585' post='23585585
[quote name='samson123' timestamp='1429594396' post='23585523']
[/quote]
[/quote]
Yes it would be- think of the OEM AP2 setup, but CE28's instead of OEM rims.
I think to better help you, I need to ask a few questions- what is most important to you? What are you willing to do in terms of fenders? What are you not willing to do? If you tell me those things then I can more accurately recommend something that will work best for what you want to do.
Originally Posted by samson123' timestamp='1429609779' post='23585602
[quote name='WhyW' timestamp='1429607585' post='23585585']
[/quote]
[/quote]
[/quote]
Rolling is fine with me. But I don't really know that much about how camber works, it seems that all the ricers in the world use the camber systems..lol. like I still want my wheels to be planted straight.
Originally Posted by WhyW' timestamp='1429617931' post='23585654
[quote name='samson123' timestamp='1429609779' post='23585602']
[/quote]
[/quote]
[/quote]
[/quote]
I think you should consider your skill level, knowledge, and goals before making this kind of commitment. Of course I don't know what kind of budget you're working with, but if you're unsure what camber even does, you might need to read up first to see what's going to suit you best before throwing money at the car.
Not trying to be a dick, just saving you from going down a path that's all for naught.
