Help need a Specialist
Old 05-05-2015, 05:41 AM
sharksfinn's Avatar
Default Help need a Specialist
Hi the great helpful people of the forum I need a recommendation for a Honda guy in Kent I have a vibration that's driving me mad and making the car not enjoyable to drive.
Its not wheel balancing or buckled rims.
Old 05-05-2015, 06:09 AM
NicoS's Avatar
Can you be more specific when it happens? Are you lowered?
Old 05-05-2015, 06:13 AM
flybikeslee's Avatar
sticky caliper
Old 05-06-2015, 11:30 AM
sharksfinn's Avatar
Hi Nico yes lowered with Eibach springs 25mm and 30mm not much but enough it happens whilst under load between third and sixth its fine coasting, Lee its not a sticky calliper.
Old 05-06-2015, 12:18 PM
mikefifth's Avatar
Any joy checking those mounts Marc?
Old 05-06-2015, 03:42 PM
Carbon S2K's Avatar
Sounds like pitted inner cv buckets?
Old 05-06-2015, 04:31 PM
NicoS's Avatar
It does sound like the problem that occurs when the s2k is lowered a lot, although I wouldn't have thought that 25 and 30mm was that much. Worth checking out those cv buckets though.
Old 05-07-2015, 10:39 AM
Mikey81's Avatar
I had a vibration on mine recently, it was mainly under load and at higher revs. It would instantly disappear as soon as I lifted off the accelerator. Internet diagnosis is never 100% but if your handy with the tools you can check it and swap side to side if you don't want to replace them just yet, it gives you time to save for the parts etc
The inner cv buckets were replaced and it doesn't do it any more.
Old 05-07-2015, 11:00 AM
Toms1989's Avatar
Yeah I'd check your CV cups mate.
I was dubious at first as I am on the same drop as yours and there was a good amount of pitting. Swapped em and regreased and all was good
Old 05-07-2015, 12:10 PM
noirenex's Avatar
I read about that as well, some folks put spacers on to move where it get's grooved in, since lowering it only a small amount will cause them not to fit in the same groove anymore, you get vibration:
https://www.s2ki.com/s2000/topic/693.../page__st__125
Quick Reply: Help need a Specialist
