Favor near Tigard or Beaverton 30 min
Requesting help from someone with a fairly stock S2000 (stock ECU) please. I need to ride along with you with an OBD2-Bluetooth connector feeding RPM & ignition timing data to my phone running the Torque app. Non-invasive, read-only, provides the data seen in text / gauges here: https://youtu.be/UQemAnnBABs
Reason is, I have an S2000 with Hondata FlashPro & what's otherwise a nice, conservative Evans autocross tune. It runs 29-30 degrees ignition advance on average at 60 MPH, flat road constant load, indicating 14-16 inches vacuum and 13-15 degrees throttle position.
That said, the FlashPro setup's highway MPG has been lower than pre-flash (bone stock) though. MPG used to be 28 highway bone-stock, now is 24-25 in same conditions.
Theory is if stock ignition timing is actually a few degrees more than 30-ish, I can easily "smooth in" the stock ignition timing in cruise for that table (and iteratively ensure same air/fuel which has been 14.7-ish) and gain back some highway cruise range. I ran 36-ish in the 9.5:1 turbo car at cruise, but that was a different compression, cams & gearing.
I'm located near Tigard/Beaverton area & glad to meet you at your convenience. Or, if someone has a stock S2000 and has already hooked an OBD2 to log their ECU data, I'd welcome your observed ignition timing at 55 MPH, constant load, flat road...
Thanks,
Stanford
Thanks,
Stanford
If I still had my Ap1, I'd kill a Saturday to head up there to let you do it, but the Ap2 has a reflash for the kraftwerks.
Hopefully someone will offer up.
Thank you both, and I welcome your insights / observations. I test drove a stock '04 today and plugged the OBD2- Torque app in and saw 35-ish degrees ignition advance, around 3100-3400 RPM and light load.
I smoothed in about 4.5 degrees into the 3D curve for my current FlashPro tune (so it hits 35-ish at those same load points) and this seems the right direction:
1 - There's no increase in knock at those RPM/load bands
2 - Looks like 1-2% less throttle position to hold a given speed vs. prior baseline log at 30 degrees advance.
Still, I welcome more info from you guys to help me solidify my confidence with this cruising map. Thanks again...
