new motec m1 series ecus
I've just finished wiring my m150 in and got it up and running. Only issue is power steering, my m800 was fine with sending a tacho signal out but something is different with the m1, it's as if it just doesn't send a strong enough signal. I have a c125 dash so can't check to see if the tacho is working on Oem dash. Should be mapping it in the next 2 weeks. I run a VW golf r32 Ddw throttle body and the m1 controls Dbw so much better than the m800 did.
Fixed the tacho output, needed a live and resistor connected to the output to get it working. Mapped it on Tuesday evening on low boost (1bar) and yesterday I blew second gear again. Ordered a quaife 69g box now and will upgrade to the gprp package and get the paddle shift working. The ecu is night and day from the m800 just operates so quick. There is a beta firmware release 1.4. I should be getting that tomorrow which has quite a few new releases, one which will be handy is your can hide bits you don't use so for example anti lag if you don't need it it will hide all the features in the software so gives a less clutted display.
